Are there other cnc-mills that are a little bit bigger than Taig and at nearly the same price level?
Hello,
Taig mill is tiny. Save some more money and get a BF20. You will be way more happy
Something ready to run ?
There's not much in the small and inexpensive turnkey cnc market. I've seen stuff on AliExpress if you're feeling brave.
Sorry, double post.
Hello,
Can that machine be run with nema 23 steppers and Gecko G540 driver, and can it be bought with ball screws?
If I thought I could figure how to get it to Norway I'd make you a good deal on a BF20L that is already converted with the PC, Mach Standard Mill license, a double 4 inch vise, TTS tooling and clamp kit.
I'm not sure what the differences are between a BF20 and a G0704, I think the G0704 is a variant or clone ?? Ball screw kits are available for the G0704 and most builds I've seen use DIY kits.
Complete cnc machine ---->https://www.automationtechnologiesin...-kit/g0704cnc/
Kit ---> https://www.automationtechnologiesin...duf-ballscrew/
How interchangeable parts are between these machines someone else may know.
The Taig is light weight but it has a decent work envelope and a fast spindle. It's also low priced and ready to run. If your work is light duty it may do all you need. Be aware the table is very narrow.
Btw last post I meant to say Alibaba not AlliExpress.
BF20 is the same as G0704 but with some castings differences.
But you would want the BF20L version that has longer X travel.
Conversion wise there are many CNC kits available. In europe there is the DamenCNC website that sells such kits.
Or you can go the Hoss way and make the 2 step conversion yourself. If you can do some machining then this would make for a nice project
