585,997 active members*
5,026 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > how to use vfd for old cnc mill
Page 3 of 6 12345
Results 41 to 60 of 111
  1. #41
    Aug 2009
    1573
    Re: how to use vfd for old cnc mill
    ....try the Fault/Status button then Reset Button to clear. Low lube should not affect Axis drives only the Cycle Start
  2. #42
    Apr 2012
    63
    Quote Originally Posted by machinehop5 View Post
    Attachment 445000
    this section of the schematic makes it seem like low way lube level would throw the same fault as hitting a x,y, or z limit switch. I think that'll be my first check this evening. the guy i bought it off of said way oil - vactra #2. Is there some easy to procure alternative to that? I don't have anywhere local to buy oil besides automotive and farm supply stores. if i top off the reservoir with hydraulic oil until i have a chance to find a distributor of way oil, would that be a big deal?
  3. #43
    Apr 2012
    63
    oops - deleting double post
  4. #44
    Aug 2009
    1573
    ....Use a straight weight (20) non detergent oil...maybe Compressor oil is easy to get for you. For Vactra2 at a good price I bought this
    https://www.ebay.com/itm/Mobil-Vactr...72.m2749.l2649
  5. #45
    Apr 2012
    63
    So I just picked up a nuance in your instructions for referencing. For some reason I had it in my head that i should go to jog - (R) reference - cycle start. I also was trying cycle start to change jog speeds. hitting cycle start was the issue. if i just select jog speed and then start using the jog buttons - it moves. so selecting R i can then use the jog -x, wait for that to complete, jog -y, wait for that, jog Z +, wait for that. then the reference error clears and everything looks good.
    so THANK YOU very much for your help. The issue came down to my reading comprehension. In my defense, the mill I used to use from time to time at my work required cycle start to be pressed as the Enter key for pretty much everything (I think...)
    Now i'm ready to start working on the VFD integration for the spindle. I'm sure i'll be back with questions.
  6. #46
    Aug 2009
    1573
    Quote Originally Posted by jaysihn View Post
    ...great It's Alive...It's Alive.
    If,you want view Lag Display and override Rapid of the Axis...use Mode Select>Setup(5)>then type TM4 ..hit Enter. You can also change Date/Time, Home position..etc in Setup.
    Jim Dawson and Al the Man will help you with the VFD ..I'm sure when you're ready.
    Enjoy,
    DJ
  7. #47
    Apr 2012
    63
    it should be safe to hook the VFD direct for now to make sure the spindle responds to the VFD keypad right? Once that is verified, i will start pulling the signal wires from the relays and get them added to the VFD.
  8. #48
    15362
    What is your motor spec's as you will have to set those Parameters in the VFD drive before you run it, and yes from the Keypad will be fine to test it
    Mactec54
  9. #49
    Apr 2012
    63
  10. #50
    15362
    Do you have the manual for the VFD Drive just a photo of one of the Parameter pages if you have it, just want to see what the Parameter format is I most likely have the manual
    Mactec54
  11. #51
    Apr 2012
    63
    I'm not sure how to direct post pictures from my phone to this forum. Here is an album with the vfd pictures...
    https://photos.app.goo.gl/E5Vr4knBwKh5TFveA
  12. #52
    Apr 2012
    63
    Attachment 445040
    what is this stuff on the top of the motor?
  13. #53
    Dec 2013
    5717
    Besides the spider web, the rest of it looks like a brake. Never seen one like that before.
    Jim Dawson
    Sandy, Oregon, USA
  14. #54
    Apr 2012
    63
    I should disconnect it and remove it and use the vfd braking right? It looks messed up, the studs are all bent up.
  15. #55
    Dec 2013
    5717
    It does look like it is in kinda rough shape.
    Does the machine have another spindle brake? Normally a lever towards the front of the head, on the left side. If not then you might want to keep the brake, maybe convert it to air actuated rather than a solenoid. With no brake, tool changing can be a bit tricky, but I do it with mine by putting it in low gear.
    Jim Dawson
    Sandy, Oregon, USA
  16. #56
    15362
    It is a very simple VFD Drive here is what to use to get you going
    Make sure the spindle is free seeing it may have a Brake that will need to be energized to release the spindle
    Main Power supply input connections R and T Plus Ground for this VFD Drive
    Pn02=100 ( this can go to 120 if the mechanic's in the head are up to the extra speed )
    Pn10=100
    Pn11=30 ( This may be able to go lower and will depend on motor Temperature and Motor cooling )
    Pn12=100
    This is all you need to set to be up and running
    Mactec54
  17. #57
    15362
    No you can not use the VFD Braking without a Braking Resistor and that is only for slowing it down not for locking the spindle for tool changes
    Mactec54
  18. #58
    Apr 2012
    63
    Pn10=100
    Pn12=100
    thank you, i'll try these settings later.
    last night i set pn02 to 60, pn10 to 60, pn11 to 40, and pn12 to 60. i briefly hit run and watched the frequency ramp from 0 to 60 but the motor never started moving so i shut it back off.
    does pn08 (acceleration time) not need adjusted?
    the motor is able to spin by hand. using the hand brake locks it up.
  19. #59
    Aug 2009
    1573
    No..its fine for testing. double check motor side wiring UVW.
    ...just had an idea. What happens if, you try a M3 or M5 command from the CNC. Relays clicking somewhere..brake etc?
    1st make a program with Mode Select>Catalog> then make a file called MDI by typing MDI hit enter (or anything you like 8 bit) exit Catalog.
    Mode Select>Edit(3)>type N1 hit enter then hit Event Type> EIA then type M3 hit enter..then Cycle start to execute...(if I remember correctly)
  20. #60
    15362
    Is the VFD Drive U V W connected direct to the Spindle Motor check the motor wiring connections that you have it setup for 230 / 240V
    The Default was fine to start with for the Acceleration and Deceleration, if it trips out with Acceleration then it would need to be increased but with such a low RPM you are using you most likely will be able to decrease it once you get it running
    Mactec54
Page 3 of 6 12345
  1. Replies: 2
    Last Post: 05-16-2016, 01:08 AM
  2. Replies: 0
    Last Post: 04-01-2016, 07:54 PM
  3. Replies: 0
    Last Post: 03-27-2016, 04:52 PM
  4. Replies: 0
    Last Post: 02-13-2016, 04:47 PM
  5. How to drill and face mill using table type horizontal boring mill
    By SatishNaik in forum News Announcements
    Last Post: 10-09-2013, 01:10 PM
