585,727 active members*
4,155 visitors online*
    Jun 2016
    S/F - Small holes in mild steel.
    Hi folks,
    I'm learning CNC machining and have been lucky enough to get access to a XYZ Proturn SLX 1630 Lathe and XYZ SMX Prtototrak 2500 Mill. (Conversational CNC machines)
    I'm past the 'absolute beginner' stage and I'm working on a small project, one of the parts is a small block with approx 400 small pockets, 1mm dia x 0.5mm deep (0.0393" x 0.0196").
    The material is mild steel,
    delivery notes class it as BS970 Bright.
    I'm using 1mm end mills for the dimples (Maybe I should have used a drill, but didn't have one that small when it came to do them)
    My mill maxes out a 3500rpm
    This block is only 30mm long and the slot is 3mm wide.
    I'm breaking cutters quite often - after talking to our tooling supply rep, they said part of the problem could be the 'budget' collet I'm using that has a 10 micron run-out. I have a higher precision 5 micron run-out on order.
    What sort of vertical feed speed should I be aiming for? I'm currently in the 10-20mm/min range, should I be trying something different?
    Thank you,
    Steve
    Jan 2018
    1516
    Re: S/F - Small holes in mild steel.
    For all those dimples I'd prefer to use this type of tool.
    https://www.ebay.co.uk/itm/4x-HSS-60...gAAOSwrYNbTegN
    More sturdy than trying to use a tiny drill bit.
    Jun 2016
    Sometimes you just need the obvious pointing out
    Got a load of those in a draw here and I never thought about using one
    Thanks.
  1. RFQ small mild steel parts- Mill
    By Centrifuge in forum North America RFQ's
    Last Post: 02-09-2017, 06:24 PM
  2. Need Small Parts Turned in Mild Steel
    By mikegiraud in forum North America RFQ's
    Last Post: 03-08-2016, 12:52 AM
  3. cut mild steel?
    By dharps in forum DIY CNC Router Table Machines
    Last Post: 04-01-2011, 03:33 AM
  4. Drilling small holes in Die steel
    By drk in forum MetalWork Discussion
    Last Post: 08-13-2008, 07:59 PM
  5. RFQ - small mild steel turned and drilled parts
    By mcmmach in forum Employment Opportunity
    Last Post: 07-29-2005, 03:37 AM
