585,991 active members*
5,407 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Milling aluminum 6061 - hazy finish
Results 1 to 9 of 9
    Oct 2017
    40
    I just received some sample parts from my machinist and would like some input before I speak with them regarding this issue.
    Some of the sample parts have a hazy, almost matte surface finish on a particular horizontal surface. I'm assuming this surface is machined with an end mill as opposed to a face mill simply due to the small size of the part and the adjacent vertical surface that lends itself to machining via end mill.
    I would like to know possible causes for this to educate myself. Any responses are appreciated.
    Apr 2004
    5737
    Re: Milling aluminum 6061 - hazy finish
    Did they do any post-machining finishing on those matte parts? Like vibro-tumbling, bulk deburring, anything like that? Ceramic media often leave a finish like that.
    Andrew Werby
    Website
    Oct 2017
    40
    Quote Originally Posted by awerby View Post
    No post finishing other than some manual deburring on some sharp edges.
    They simply changed end mills mid stream for whatever reason. One the very end of the end mill is sharp, the other not so. Same tool path. Same everything. You can even see a very slight burr on the dull tool part. I doubt it's going to make any difference at all how the part works. If you did not spec any surface finish tolerances or supply samples, you have nothing to stand on. It's not poor machining per say. I'm sure the person had an, oh sh*t, I don't like what that end mill is doing any more. Time to change it out. Situations like that are not uncommon.
    On second thought it might even be from a different stick of raw stock. Every once in awhile aluminum will change a little on you from one stick to the next. Mostly though I think it's a dull-ish cutting end.
    I like the hex work. That's pretty sweet.
    Jan 2018
    1516
    I find flood coolant can make parts look dull too.
    Oct 2017
    40
    Thx for the replies. It's possible they switched tooling between samples. I'm curious to know the type of tooling and feeds/speeds used. I will ask.
    Aug 2009
    1573
    ...maybe add a surface finish tolerance to your drawing for that area, than the machinist would know to slowdown feed rates. There are devices called a Profilometer if, you really want to check a surface.
    https://en.wikipedia.org/wiki/Profilometer
    DJ
    Oct 2017
    40
    Quote Originally Posted by machinehop5 View Post
    DJ
    There is a 0.8 RA finish on that surface (micrometer). I've not been able to justify the high cost of a profilometer. I just go by look and feel.
    Just remember, adding tolerances of any type, especially critical or tight ones and perhaps especially surface finish, come with the associated dollar signs attached to them.
    In general, I wouldn't call the end of an end mill the best surface finish tool around. Wiper flats can help, but still.
  1. 6061 Aluminum Milling Help
    By drone6251 in forum Benchtop Machines
    Last Post: 12-24-2017, 05:13 PM
  2. Bad cutoff Finish in 6061 Aluminum
    By jmk021083 in forum CNC Tooling
    Last Post: 08-09-2016, 12:53 AM
  3. Aluminum 6061 Milling advice
    By figure1a in forum Uncategorised MetalWorking Machines
    Last Post: 03-16-2012, 10:52 PM
  4. Best milling finish on 6061
    By SRT Mike in forum MetalWork Discussion
    Last Post: 03-31-2011, 03:35 PM
  5. 6061 aluminum finish ??
    By twocik in forum Mass finishing equipment/media/strategies
    Last Post: 11-01-2008, 05:37 PM
