586,011 active members*
4,057 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > No Alarms air pressure, door open , Oil cooler
Results 1 to 8 of 8
    Mar 2009
    6
    Please help. I wants alarms back.
    I have just bought an old Feeler FV600 milling machine and it is not showing alarms fx. door open, Spindle Oil cooler alarm and Air pressure low alarms are not shown on the monitor. The alarms are working, cause I cannot move the XYZ axis when the door is open. And I cannot start the spindle without the Oil cooler is connected. Some alarms are shown on the monitor fx. overtravel alarm are shown.
    I think it is a parameter that are wrong, but I have no idea which one.
    Re: No Alarms air pressure, door open , Oil cooler
    What controller do you have? is it possiable to post the ladder so we can take a look at it?
    On an old machine like that, it's completely possible that the devices and sensors that signal the control about the state of the machine's ancillary equipment are either non-functioning or disconnected. If possible, check the X adresses for each signal device, whether by manual manipulation or meter check. If you're not getting bit changes, then the sensors are your problems and the alarms are potentially functioning. It you're getting bit changes with sensor actions and still no alarms, then your problems are deeper then I have the skills to help you with.
    I don't recall many if any instances where the MTB gave you control over forcing alarms off permanently. There might be a few, but if it were my guess, door interlocks and low air wouldn't be on that list.
    Mar 2009
    6
    Hi drdos.
    It is A Fanuc 0M and C version. How do I make a Ladder export? Can you use a backup of PMC diagnostic parameter?
    PMC parameters:
    N10300 P 00000000
    N10301 P 00000000
    N10302 P 00000000
    N10303 P 00000000
    N10304 P 00000000
    N10305 P 00000000
    N10306 P 00000000
    N10307 P 00000000
    N10308 P 00000000
    N10309 P 00000000
    N10310 P 00001010
    N10311 P 00000000
    N10312 P 00001100
    N10313 P 00000000
    N10314 P 00000011
    N10315 P 00000010
    N10316 P 00000000
    N10317 P 00110101
    N10318 P 01110010
    N10319 P 00000000
    N10320 P 00000010
    N10321 P 00000000
    N10322 P 10111010
    N10323 P 10010110
    N10324 P 00000000
    N10325 P 00000010
    N10326 P 00000000
    N10327 P 10010101
    N10328 P 00000000
    N10329 P 00000000
    N10330 P 00000010
    N10331 P 00000000
    N10332 P 00000000
    N10333 P 00000000
    N10334 P 00000000
    N10335 P 00001010
    N10336 P 00000000
    N10337 P 00001100
    N10338 P 00000000
    N10339 P 00000011
    N10340 P 00000100
    N10341 P 00000000
    N10342 P 01011000
    N10343 P 01000100
    N10344 P 00000000
    N10345 P 00001010
    N10346 P 00000000
    N10347 P 01100001
    N10348 P 01000100
    N10349 P 00000000
    N10350 P 00001010
    N10351 P 00000000
    N10352 P 00000000
    N10353 P 00000000
    N10354 P 00000000
    N10355 P 00101110
    N10356 P 00000000
    N10357 P 01011011
    N10358 P 11111110
    N10359 P 00000000
    N10360 P 00000000
    N10361 P 00000000
    N10362 P 00000000
    N10363 P 00000000
    N10364 P 00000000
    N10365 P 00001010
    N10366 P 00000000
    N10367 P 10101100
    N10368 P 00000010
    N10369 P 00000000
    N10370 P 00000100
    N10371 P 00000000
    N10372 P 10000111
    N10373 P 01000100
    N10374 P 00000000
    N10375 P 00000111
    N10376 P 00000000
    N10377 P 00000000
    N10378 P 00000000
    N10379 P 00000000
    N10380 P 00001010
    N10381 P 00000000
    N10382 P 10110101
    N10383 P 01110100
    N10384 P 00000011
    N10385 P 00001010
    N10386 P 00000000
    N10387 P 11000000
    N10388 P 01110100
    N10389 P 00000011
    N10390 P 00101100
    N10391 P 00000001
    N10392 P 00010000
    N10393 P 01000101
    N10394 P 00000000
    N10395 P 01110000
    N10396 P 00010111
    N10397 P 10000001
    N10398 P 01011100
    N10399 P 00000000
    N10400 P 00001010
    N10401 P 00000000
    N10402 P 00000000
    N10403 P 01101100
    N10404 P 00000000
    N10405 P 00000000
    N10406 P 00000000
    N10407 P 00000000
    N10408 P 00000000
    N10409 P 00000000
    N10410 P 00000000
    N10411 P 00000000
    N10412 P 00000000
    N10413 P 00000000
    N10414 P 00000000
    N10415 P 00000000
    N10416 P 00000000
    N10417 P 00000000
    N10418 P 00000000
    N10419 P 00000000
    N10420 P 00000000
    N10421 P 00000000
    N10422 P 00000000
    N10423 P 00000000
    N10424 P 00000000
    N10425 P 00000000
    N10426 P 00000000
    N10427 P 00000000
    N10428 P 00000000
    N10429 P 00000000
    N10430 P 00001010
    N10431 P 00000000
    N10432 P 00000000
    N10433 P 00000000
    N10434 P 00000000
    N10435 P 00001010
    N10436 P 00000000
    N10437 P 00000000
    N10438 P 00000000
    N10439 P 00000000
    N10440 P 00100010
    N10441 P 00000000
    N10442 P 00100000
    N10443 P 00000000
    N10444 P 00000000
    N10445 P 00011000
    N10446 P 00000000
    N10447 P 00100000
    N10448 P 00000000
    N10449 P 00000000
    N10450 P 00000000
    N10451 P 00000000
    N10452 P 00000000
    N10453 P 00000000
    N10454 P 00010111
    N10455 P 00000000
    N10456 P 00000011
    N10457 P 00000000
    N10458 P 00000000
    N10459 P 00000000
    N10460 P 11111111
    N10461 P 11001111
    N10462 P 00000000
    N10463 P 00000000
    N10464 P 00000000
    N10465 P 00000000
    N10466 P 00000000
    N10467 P 11100010
    N10468 P 10110111
    N10469 P 00000000
    N10470 P 00000000
    N10471 P 00000000
    N10472 P 00000000
    N10473 P 00000000
    N10474 P 00000000
    N10475 P 00000000
    N10476 P 00000000
    N10477 P 00000000
    N10478 P 00000000
    N10479 P 00000000
    N10480 P 00000010
    N10481 P 00000000
    N10482 P 00011000
    N10483 P 00010000
    N10484 P 10000010
    N10485 P 00000001
    N10486 P 00100000
    N10487 P 00000000
    N10488 P 00000000
    N10489 P 00000000
    N10490 P 00000110
    N10491 P 00000101
    N10492 P 00000000
    N10493 P 00000000
    N10494 P 00000000
    N10495 P 00000000
    N10496 P 00001000
    N10497 P 00000000
    N10498 P 00000000
    N10499 P 00100000
    Mar 2009
    6
    I have found the problem :banana:. It was the parameter 906#6 EXTERNAL MESSAGE that was 0 It need to be 1 on Feeler FV to send messages from the PMC-L
    Quote Originally Posted by Mikzy View Post
    Hi drdos.
    You need a PMC EDIT cassette to get to the screen to punch out the ladder.
    Mar 2009
    6
    Thank´s drdos
    I think it will be a good idéa to have a PMC casette Will this one work? Found this one on ebay.
    Attachment 445434
    Do you have some dokumentation on where I have to connect it and how to read write from it?
    Thank´s drdos
    Attachment 445434
    No, that is a PMC Ladder Cassette for the series 15A. What I am talking about is an EDIT Cassette A02B-0098-C199. They were field service/OEM issued only. If you find one make sure that you have everything backed up before using I had a few machines go into RAM parity alarm when using them.
  1. (FANUC 0i) Wanna stop high pressure when the door opens
    By jaeohck in forum CNC Swiss Screw Machines
    Last Post: 10-19-2017, 08:32 PM
  2. Door won't open
    By stevemay55 in forum Hardinge Lathes
    Last Post: 10-27-2016, 02:38 PM
  3. Incessant Pneumatic Pressure Alarms on Citizen A20
    By PoiToi in forum CNC Swiss Screw Machines
    Last Post: 05-15-2016, 06:04 AM
  4. open the door M0
    By Parametisierer in forum HEIDENHAIN -> MillPlus
    Last Post: 03-16-2012, 10:47 PM
  5. Door Open
    By North Forty in forum Haas Lathes
    Last Post: 09-02-2010, 04:46 PM
