585,717 active members*
3,995 visitors online*
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    May 2012
    537
    Re: 4th Axis With Argon Drive
    Here is my code to clamp:
    Code:
    #include "KMotionDef.h"
    main()
    	Delay_sec(0.25); // wait for everything to stop
    	ch3->MaxOutput=1;  // reduce max gain
    	ch3->I=0.0;	// reduce integrator
    	SetBit(53); // turn on brake
    	while (!ReadBit(1052)) WaitNextTimeSlice(); // Wait for clamped signal
    And here is the code to unclamp:
    Code:
    main()
    	ClearBit(53); // turn off brake
    	while (!ReadBit(1053)) WaitNextTimeSlice(); // Wait for unclamped signal
    	ch3->MaxOutput=2000;  // increase max gain
    	ch3->I=0.010;	// increase integrator
    I just configured my M30 to unclamp so it unclamps at the end of every program, and you will also want to do the same thing for your halt/reset button. So anytime im not running g-code, its unclamped. If I ever need to do some very heavy hogging with the MPG (not likely) ill just use the M code in MDI to reclamp.
  2. #22
    Dec 2007
    578
    Hi Murray,
    That is the same code i made minus the "disabling" of servo.
    The M30 config is a simple solution, thanks
    Troy
Page 2 of 2 12
  1. Will Argon drive work with Sanyo motor
    By medu2015 in forum CNC Machine Related Electronics
    Last Post: 07-29-2016, 05:10 AM
  2. encoder on Argon drive together with sinumerik 808D basic
    By slektning in forum CNC Machine Related Electronics
    Last Post: 02-23-2016, 08:09 PM
  3. I am a newbie, Argon drive with Mach 3?
    By machining fool in forum CNC Machine Related Electronics
    Last Post: 08-18-2015, 06:06 PM
  4. Will Argon drive work with a more powerful servo?
    By richienz in forum CNC Machine Related Electronics
    Last Post: 05-25-2015, 01:41 AM
  5. Argon drive stepper + encoder?
    By nicad in forum CNC Machine Related Electronics
    Last Post: 09-19-2013, 10:00 PM
