585,942 active members*
3,156 visitors online*
    plasma z axis and proma 150 thc, linit switches
    Hi i have nearly finished my first cnc build, but would appreciate some help.and this is my first post.
    i am using ucnc and an axbb board,
    the thc proma 150 in test is working well, and it moves the z axis up and down . what i am having problems with is a few things,
    1) the floating axis i have for the torch, does not operate, (i have not using any code but just doing everything from the uccnc software. the switch , i have set to probe, and this opens and close the contact in the diagnostics, However it does not operate in practice. i have cut some steel up manually and it would be useful to get the z axis at the right start height? is this a way uccnc is set up, or is this something that will always happen without using something like sheetcam?
    2) when cutting manually , if i start the arc, the gantry will not move? i need to start movement and then press the arc button. Again have i set this up wrong?
    3) i am also having a problem with the limit /home switches, to be honest i have not got a clue whats going wrong, when i hit a limit switch and it is open, the error message comes up, i press reset, also look in the diadnostics, but it will not restart, even if i press override,
    could you tell me the bst way of setting this up please. at the moment i only have one input available, and i have the 6 switches in series.
    not being used to cnc machines this is something i an not clued up on, but every days a laerning day.
    Re: plasma z axis and proma 150 thc, linit switches
    no 3 fixed , was a setting in uccnc , i did not have a tick box checked , for the amount of distance for the axis to move after it hit the home switch.
    still having problems with 1 and 2.
  1. Proma Plasma Controller with THC - New
    By NSchlee in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-20-2020, 11:30 AM
  2. CNC Plasma Proma torch heigh control step dir
    By tim74523 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-24-2019, 07:48 PM
  3. Proma 150 THC (Torch Height Controller) for Plasma CNC
    By Tacomaster5000 in forum For Sale Only
    Last Post: 02-08-2018, 10:03 PM
  4. Proma SD + Mach3 + plasma CUT50L (chinese) + M3/M5 macro + detect material + AHX-MK4
    By stan_ro in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-24-2016, 09:49 AM
  5. Replies: 2
    Last Post: 04-13-2016, 06:45 PM
