585,717 active members*
3,938 visitors online*
    810D is my backup good?
    My Emco does not not boot. It hangs on the green screen and when I press something I get "waiting for NCK connection".
    PCU20
    Someone told me it might corrupt software and I should press the "reset" button inside the machine and play back the backup.
    I have an backup folder which is as below. Is that a valid backup? It seems so small in size?
    My point is: If that backup is not a real backup. And my machine has a complete different problem and I press "reset", I have afterwards 2 problems.
    Of course no one will be able to tell me if the backup is good....but does it look reasonable?
    thx
    Michael
    Sep 2009
    99
    Re: 810D is my backup good?
    Hi H90,
    You will need to open your back panel and see what display is shown on the CCU card. The CCU card has a seven segment LED display and about 8-10 LED lights below that.
    The waiting for NCK connection error basically occurs where there is something wrong on your CCU card side. If you're lucky, its just a software issue.
    The software backup being referred to is saved as an ARC file and normally saved in your PCU20 if i'm not mistaken.
    The process for reloading the backup is well documented on the siemens forum- you should check over there.
    Best of luck!
  1. Backup router needed. 6040 a good option?
    By anthropod in forum Chinese Machines
    Last Post: 04-11-2019, 06:05 PM
  2. Sinumerik 810D
    By Melkiades in forum Alphacam
    Last Post: 10-13-2018, 10:34 AM
  3. Fadal 4525 Sinumerik 810D Backup
    By megaman26 in forum Fadal
    Last Post: 03-06-2017, 06:22 AM
  4. SIEMENS 810D BACKUP
    By jose cnc in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 05-03-2012, 03:59 AM
  5. adding USB to 810D VMC
    By ShawJohn in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 12-15-2011, 01:58 AM
