585,922 active members*
3,633 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact 1 Mk2 with TNC 2500 missing 110V on wire 8 and 9 when power on.
    Oct 2019
    19
    Dear all, good day.
    I have purchased a Bridgeport Interact 1 Mk2 milling machine that was operational before transfer it to Cyprus in a container.
    It has a Heidenhain TNC2500 control.
    Cyprus has same power specs as in UK.
    I have followed the instructions in the manual for the main power connection R.Y.B. - L1, L2, L3.
    The problem is when I am powering on the machine I cannot get the 110V at point 8 and 9 as mentioned in the manual, therefore I am not able to get the machine in operation.
    we have checked the transformers and input and output are correct.
    both Emergency switch are not pressed in and also checked for proper functionality.
    What might be the reason? Could you pls support?
    Thank you in advance.
    Nikos
    May 2016
    526
    Re: Bridgeport Interact 1 Mk2 with TNC 2500 missing 110V on wire 8 and 9 when power o
    nikos
    Did you check the overtravel switches
    Oct 2019
    19
    Quote Originally Posted by mbservice View Post
    nikos
    good day mbservice.
    yes i did.
    all in order.
    any other idea?
    BR
    Nikos
  1. Bridgeport interact 300 + tnc 2500
    By tone_ in forum Bridgeport / Hardinge Mills
    Last Post: 03-05-2018, 09:12 PM
  2. Bridgeport Interact - Heidenhain TNC 2500
    By nycooh in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-08-2011, 09:01 PM
  3. Bridgeport Interact with TNC 2500
    By bk1955 in forum Bridgeport / Hardinge Mills
    Last Post: 08-05-2008, 12:18 AM
  4. Bridgeport Interact 1 - Heidenhain 2500
    By nycooh in forum Uncategorised MetalWorking Machines
    Last Post: 06-25-2007, 09:59 AM
  5. Bridgeport Interact 1 MK 2 TNC 2500 control
    By JohnPW in forum Bridgeport / Hardinge Mills
    Last Post: 05-14-2007, 04:50 AM
