585,931 active members*
4,750 visitors online*
IndustryArena Forum > CAM Software > EnRoute > How to enter the router
Results 1 to 1 of 1
    Jun 2020
    Post How to enter the router
    If you recently bought a new router for your network, you will definitely start configuring various parameters of your internet connection.
    To do this, you must enter the router in order to manage all the control settings. This is a fairly common and uniform process for any device.
    Now, you can easily enter routers like Zyxel, TP-Link, D-Link, Netgear, etc. Whoever you want..
    How to enter a router: a general guide
    Whether it is a modem router for ADSL, VDSL, fiber or a simple wireless router, the process is always the same and it is very simple.
    You should know that the administration of the router is through an interface that can be accessed directly from the browser. For example, Google Chrome, Mozilla Firefox or Microsoft Edge.
    Login To Router, you must type your IP address in the address bar of the browser. The IP address, as the expression itself says, is the address assumed by the router within its local network, and each router generally has a default value of how to find the gateway IP address to find it. Take the help of our guide. .
    Once you find the IP address of your router, you can type it into the address bar of the browser. A screen will open where you must enter your username and password.
    The standard option is usually:
    Username: admin, password: admin
    Username: administrator password: password
    Try these two combinations, they generally always succeed if you haven't changed your router's default password.
    How to Access Telecom Router (TIM)
    TIM is one of the most popular telephone operators in Italy. Therefore, it is not surprising that your home may have a telecommunications router. As a rule, these are basic tools that have fairly simple firmware.
    If you are looking for more advanced features, you may be interested in Cascade Routers. You will get the best router available today at this link!
    However, entering a telecom router is a fairly simple operation.
    The IP address is usually:
    192.168.0.1
    or:
    192.168.1.1
    Depending on the manufacturers the operator trusts.
    Once you reach the web administration interface, you will eventually have to enter a username and password to login.
    For telecommunications routers, these are the most:
    Username: admin. administrator password
    Username: Administrator. administrator password
    At this time the first thing you will be asked is the password to use the interface (and change the username if you wish).
    Remember, this is a valid process for both VDSL routers that connect to fiber optics and those that connect to the ADSL line.
