585,996 active members*
4,171 visitors online*
Thread: gecko wiring
Results 1 to 6 of 6
    Nov 2018
    26
    gecko wiring
    Hi, I've decided to upgrade my machine to a gecko g540 and was wondering if anyone had built their own recently. I've been using the diagram from Homann designs. But, I wanted to simplify it a fraction.
    I've adjusted the original diagram to exclude the second relay, and change the e-stop position with the kcd2 switch. I was wondering if this would work?
    cheers, Paul
    Aug 2005
    1092
    Re: gecko wiring
    That will work, but it is NOT SAFE.
    If there is a fault with the G540 FETs that suddenly turns on the relay, say starting the spindle, pushing the reset will do nothing.
    That’s why the EStop needs to always remove AC power from the system and make it safe.
    Also, you do not have my approval to modify and distribute my diagrams, especially when they are modified to present an unsafe schematic.
    Please delete it.
    Cheers,
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
    Nov 2018
    26
    Re: gecko wiring
    Quote Originally Posted by phomann View Post
    Please delete it.
    Cheers,
    Peter
    Hi PHomann, Sorry ,
    But it was not my intention to misguide or misdirect anyone, far from it. My intention was to ask if it would work? It seems that not only can I not remove the download, but I cannot find help to do so.
    Again, apologies. I'll remove myself from the site.
    Aug 2005
    1092
    Re: gecko wiring
    Don’t sweat. I just can’t have a diagram like that circulating on the web.
    Normally there is an “edit” button for the author that you can use.
    If not see if you can contact an administrator.
    Don’t leave the forum though.
    Cheers
    Peter
    Apr 2019
    154
    Re: gecko wiring
    Hello Guys, I´ve deleted the attachment now. For a member it´s only possible to edit a thread within one hour after posting, sorry.
    However, nobody has to leave the forum
    Aug 2005
    1092
    Re: gecko wiring
    Thanks for that.
    Cheers
    Peter
  1. Wiring Gecko G540 to PSU
    By rnm85 in forum DIY CNC Router Table Machines
    Last Post: 01-08-2012, 02:48 AM
  2. Gecko 540 wiring
    By speedtwin69 in forum Benchtop Machines
    Last Post: 01-18-2011, 04:23 AM
  3. Gecko Wiring
    By crash5050 in forum Gecko Drives
    Last Post: 04-23-2010, 01:09 PM
  4. wiring from gecko's to motors
    By project5k in forum CNC Machine Related Electronics
    Last Post: 09-21-2007, 12:22 PM
  5. Gecko wiring question
    By LEWENZ in forum Gecko Drives
    Last Post: 12-23-2006, 03:48 PM
