585,604 active members*
3,486 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > CNC Standard File format for tube bending
Results 1 to 7 of 7
    Nov 2019
    16
    Hi all,
    I have questions about standard format accepted by CNC, for CNC Plasma Cutting, I see DXF or GCode as the most common, any clue why LinuxCNC seems to accept only GCode?
    What about tube bending?
    What format use the CNC Tube bender?
    I'm designing a CNC Tube bender, it's gonna be fully controlled by Servo motor.
    The controlling part will be done using Arduino based PLC.
    So i need to somehow pass the bending data, so what is the standard?
    I was thinking it could probably be extracted directly from step file. Is it a common way?
    is CNC bender accept Gcode or DXF or sonething else?
    Thank you very much
    Nov 2012
    1267
    Re: CNC Standard File format for tube bending
    Quote Originally Posted by garthos View Post
    DXF is a drawing format, not machining format. The reason why many plasma controllers accept it is that a 2D drawing can be easily translated to torch movement. If you give a plasma machine a drawing of a 3x3" square, it will cut a 3x3" square.
    LinuxCNC is a general purpose CNC controller. If you give it a drawing of a square, it would have no idea what to do with it. Cut a hole? Mill a pocket (how deep)? Engrave? It takes CAM software to translate a drawing to tool movements.
    I guess a bending machine would use either G-code, or its own proprietary format.
    Nov 2019
    16
    Quote Originally Posted by CitizenOfDreams View Post
    Actually I will develop the software so I'm not gonna use LinuxCNC but an Arduino based PLC, so I'm trying to know how commercial solution does to go from the design (for example Solidworks) to the machine to do the bend.
    I guess it's probably good to go for STEP/INGES format as it will contain all the required information.
    I would like to be able to import the bend sequence from my design instead of programming it manually, actually will have both possibility as I will start by manual programming of the machine and later adding the import of whatever format that will be convenient.
    As I will need to do some research to find the appropriate libraries, I'm anticipating
    I should be able to find some C++ libs that will allow me to read such format, but I could implement other format as well if it's useful.
    I'm trying to know what would be the most convenient as I want to later publish all as an open source project.
    Nov 2012
    1267
    The way I see it, you will need to somehow analyze the part design and translate it into a series of machine movements, something like:
    FEED 3 inches
    CLAMP
    BEND 135 degrees
    UNCLAMP
    FEED 10 inches
    ROTATE 180 degrees
    CLAMP
    BEND 45 degrees
    UNCLAMP
    It does not really matter what language you choose for your controller. It would be trivial to translate, say, "ROTATE 180" to "G1 A180".
    Nov 2019
    16
    FEED 3 inches
    CLAMP
    BEND 135 degrees
    UNCLAMP
    FEED 10 inches
    ROTATE 180 degrees
    CLAMP
    BEND 45 degrees
    UNCLAMP
    Yes of course, it's gonna be translated like that, the question was more, according to you guys, what would be the most convenient source to extract this information, STEP/INGES file ? or I don't know what format?
    I'm not a professional so I'm wondering how professional work from the design to the bend, so basically what file format they use as output of solidworks or catia and then what format go in the CNC?
    is it usual that machine directly take format such STEP/INGES or something else? is the manufacturer then provide some kind of converter?
    It's just my hobby, I'm not mechanical engineer but I'm software engineer, I also studied mechanical engineering so that's why I have some base I can design stuff on Solidworks but I never practicing professionally as a job, so this is why I have some many questions
    Feb 2007
    191
    Hello, I am trying to build a cnc steel sheet metal bender
    Basically for bend Dies for cardboard cutting.
    The proccess is similar to tube bending but also I dont know
    How to program the gcodes.
    From a GCode of one strategy like Machine along the vector
    I think that using excell its possible to caculate the bend Gcode
    Only I need to calculate the lenght of each piece of the steel rule
    Using the hiphotenuse formula
    The bend angle should be calculating the angle between 2 consecutive lines using the Sinus Law.
    I have made similar calculations for hand drawing of polygons in Topography. For a long gcode will be very tedious.
    I would like to know if you finish your project and if you like to share your development.
    Thanks in advance
    May 2015
    686
    I think you'll find most machines are controlled by gcode
    I think Linuxcnc would be a good choice as you can write custom components for it.
    You just need to have some maths that converted the distance the ram needs move to achieve a given angle and it becomes just another X,Y axis machine and add a rotary axis to rotate the tube.
    SO I would write a custom component in linuxcnc that accepted as input the parameters defining bend angle. and output a distance to move.
    Rod Webster
    www.vehiclemods.net.au
