524,308 active members*
1,671 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > I-beam bridge design - my head is spinning...
Results 1 to 2 of 2
    Registered
    Mar 2007
    29
    I'm trying to come up with a suitable bridge design for my property to span a creek, and could use some help with all the formulas. This will be a simply-supported bridge, and the length of the i-beams that I have available is 18'. The beams measure 6" x 6" x .25" thick all over. I plan to space the beams to be directly under my compact tractor's tires (approx. 45" apart center-to-center). The bridge will be decked with lumber (2 x 8's ?). No support underneath in the middle of the span.
    I'm trying to determine if this will be sufficient to support a max load of ~6000 lbs (tractor w/FEL, tires weighted with beet juice, loaded bucket, rotary cutter & driver) and what the max deflection in the center might be. I can use an additional i-beam (for a total of 3) for the bridge. I have 6 i-beams total, but would like to construct at least 2 bridges.
    Any insight you might be able to offer? If it turns out to be overkill, I'll go for it. If it's only marginally adequate or completely inadequate, I'll have to come up with a better solution.
    -WRM
    Community Moderator ger21's Avatar
    35000
    Re: I-beam bridge design - my head is spinning...
    Download Beamboy.
  1. covered bridge i-beam help.
    By Trippy in forum Mechanical Calculations/Engineering Design
    Last Post: 03-30-2018, 12:32 AM
  2. Design Options: Moving bridge vs. Moving Cross Beam
    By martin_05 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-22-2014, 08:20 PM
  3. I-Beam Bridge
    By Dako in forum Mechanical Calculations/Engineering Design
    Last Post: 08-11-2011, 06:02 AM
  4. Beam strength for miniature railway bridge
    By Web.eng in forum Mechanical Calculations/Engineering Design
    Last Post: 01-22-2010, 01:48 AM
  5. Short beam/Long beam? - Basic design
    By Pat2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2005, 05:49 AM
