585,931 active members*
3,724 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Enhanced structure cnc water jet cutting machine EK3020
Results 1 to 1 of 1
    EAAK Enhanced waterjet cutting machine EK3020N applications:
    The cutting materials are not limited (such as stainless steel,carbon steel,copper,brass,aluminum and other metal,glass,stone,marble,granite,foam,ceramics,pla stics,composite materials.), waterjet cutting is currently the most applicable cutting method;
    Metal cutting:
    1 Decoration of stainless steel,aluminum.iron,brass and other metal cutting process.
    2 Manufacture of machinery and equipment control cabinets such as food machinery,medical machinery,CNC machinery.
    3 The metal parts cutting such as stainlesssteel flange,semi-finished,steel construction, non-ferrous metal and so on.
    Glass cutting:
    1 Gas stove surfaces, range hood,disinfecting cabinet, TV, bathroom products.
    2 Construction and decoration glass,automotive glass.
    Ceramic and stone cutting:
    1 Ceramic cutting for decoration and construction.
    2 Marble mosaic,granite mosaicmstone plate cutting.
    Specification of EAAK CNC waterjet cutter machineryas follows)
    Model EK3020N
    X Y axis Working size 3000mm*2000mm
    Z working height 150mm
    Cutting Pressure 420Mpa 37kw UHP pump
    Control accuracy 0.01mm
    Cutting accuracy 0.1-0.2mm
    Repositioning Accuracy 0.05mm
    Max cutting thickness 300mm(depends on materials)
    Max. moving speed 6000mm/min
    Power supply 380V 50Hz
    Environmental temperature -10-50°C
    Max flow rate 3.7L/min
    Max oil discharge 206L/min
    Max delivery capacity of oil pump 106L/min
    Control system Ncstudio (Shanghai) software IPC controller
    CAD/CAM software AutoCAD,ArtCAM
    Drive motor Japan Yaskawa servo drive motor
    Attached Thumbnails Attached Thumbnails eaak-3020-enhanced-waterjet-metal-cutter.jpg
  1. EAAK water jet cutting machine EK3020 for glass marble cutting
    By sinowaterjet in forum News Announcements
    Last Post: 11-09-2019, 10:42 AM
  2. Request of water quality for Sino water jet cutting machine
    By Sino-waterjet in forum Machinery Manuals / Brochures
    Last Post: 03-22-2013, 02:18 AM
  3. Replies: 3
    Last Post: 09-19-2010, 02:40 PM
  4. Replies: 0
    Last Post: 09-17-2010, 09:09 AM
