585,931 active members*
4,875 visitors online*
Results 1 to 3 of 3
    Oct 2011
    38
    Emco 320 config file / sheet
    Here's the config file and sheet for my Emcoturn 320 with Fanuc O-TC controls, My machine is configured with a LNS Hydrobar bar feeder so you will have to figure out how to remove that part if you don't have one.
    You will have to delete the .txt off the config file.
    Hope this helps someone
    Attached Files Attached Files
    Oct 2013
    3
    Re: Emco 320 config file / sheet
    Thank You!
    Oct 2011
    38
    Quote Originally Posted by DT714 View Post
    Thank You!
    Did you ever get your Emco running?
  1. NM-145- need config file (XML?)
    By steveb946 in forum Novakon
    Last Post: 10-06-2016, 08:20 PM
  2. Config file for Series 3 Tormach
    By mike sr1 in forum LinuxCNC (formerly EMC2)
    Last Post: 04-16-2014, 05:40 PM
  3. syil x4 speedmaster config file
    By gazzer in forum Community Club House
    Last Post: 09-02-2013, 09:57 AM
  4. Mach3 Config file
    By ltcjr71 in forum Charter Oak Automation Support Forum
    Last Post: 12-17-2010, 02:57 AM
  5. Mach 3 driver config file
    By Drakkn in forum Mach Software (ArtSoft software)
    Last Post: 08-10-2007, 08:17 PM
