585,973 active members*
4,039 visitors online*
Results 1 to 8 of 8
    ESS/MB3 VFD wiring
    Hello I have a Huanyung VFD with 2.2kw spindle and I just can't figure out how to wire my VFD to the MB3 directly. At the moment I have the following connection:
    VFD --> MB3:
    0V --> A0
    10V --> AG
    FOR --> NO1
    REV --> NO2
    And obviously it isn't working. Now I have tested the VFD with an RS485 to USB adapter and it worked perfectly. The issue is that after a while Mach3 will not recognize the adapter anymore and I have to replace it with a new one. They are cheap but I just don't want to keep doing that. I just want to hook it all up in one place at the MB3 and be done with it.
    If you guys can walk me through this I would really appreciate it! Here is a picture from the manual but I cannot figure it out:
    Re: ESS/MB3 VFD wiring
    Your AO and AG are wrong I think. What VFD is this, is it a GT series?
    I am not sure to be honest cause there is no label anywhere on it. Here's a picture of the available ports.
    24221
    ACM is your analogue common, V1 is the analogue input.
    Al.
    Albert E.
    I have never wired one of these before so I have no idea what that means. I understand that it needs 0-10v to control the frequency and I have configured the VFD side correctly. However I have no idea what to plug in where and what settings to put into Mach3. So far I have tried this as well and it doesn't work either:
    ACM+DCM ---> AG
    FOR --> NO1
    VI ---> A0
    I measured and I am picking up 24v between VI and ACM/DCM and also between ACM and FOR. I thought it is 10v max?
    Here is a picture of the controller itself:
    Is there a way to use the RS+ and RS- like I did with the USB controller? It was just two wires and very simple to do.
    MB3 --- VFD
    AO --- VI
    AG --- ACM
    NO1 --- FWD
    CM1 --- DCM
    NO2 --- REV
    CM2 --- DCM
    Yes, if you get RS-485 converter, and a Mach3 Huanyang plugin
    Most people use this plugin. Mach3 plugin for Huanyang VFD | Le royaume d'éole
    Jan 2007
    626
    This is how I did it. My VFD may be labelled differently.
    Attachment 445170
  1. 8 wiring encoder wiring to step2linear
    By taoufikbenzart in forum Viper Servo drives
    Last Post: 11-24-2019, 08:41 PM
  2. vfd wiring
    By swe in forum Spindles / VFD
    Last Post: 10-10-2016, 01:16 AM
  3. Replies: 19
    Last Post: 07-30-2015, 01:44 AM
  4. wiring check please. parallel wiring to maximum current to servo motors
    By Novett in forum CNC Machine Related Electronics
    Last Post: 10-11-2014, 07:54 PM
  5. Another sPID, G540, and Mach wiring question for the wiring challenged..
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 01-02-2014, 01:29 AM
