WHEN I WANT TO USE the COMPENSATION OF RADIO G41 G42 I WRITE G41 P1 Or G42 P1, BUT the CUT LAYOUT IS NOT CORRECT, MAKES FORMS THAT DO NOT FOLLOW the PROFILE OF the PIECE OR CUTS IN DIAGONAL, IS SOME PARAMETER TO FIT THIS?
MANY THAKS
CARLOS
MANY THAKS
CARLOS
P is the tool diameter, so if you use P1 you'll get a 1/2" offset. Also, you need to add a lead in move for comp to be applied. If you can upload a .dxf and your code I'll give you a hand with it.
This Is A Copy Of The Drawing And The Program .
Many Thanks
Carles
Try this. It's in absolute mode, and yours was incremental. The P specifies half the plasma kerf.
Try this. The P specifies half the plasma kerf. I just guessed and used .5, assuming your using mm. Also, this is in absolute mode, yours was incremental.
