584,842 active members*
4,512 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Spindle rotate while door open
Results 1 to 6 of 6
    Feb 2015
    13
    Hello Friends,
    Im working on Haas VF-2-I Machine.
    According to Haas its possible to rotate spindle maximum of RPM 750 while door is open.
    This feature essential for using edge finder.
    But my machine cant rotate the spindle while door is open.
    I search for setting number 292. Its not on the controller.
    Appriciate someone can help me.
    Thank in advanc.
    Aug 2009
    1567
    Re: Spindle rotate while door open
    ...in jog mode ?
    Jul 2020
    If your machine is newer then 2016 and has software newer the 100.17.000.XXXX then that setting no longer exists. Unfortunately you cannot run the spindle with the doors open.
    Feb 2015
    13
    Quote Originally Posted by MMTapps View Post
    Thanks.
    The software version is 100.19. I will try to override the sensors. The feature is very useful while using edge finder.
    15362
    Quote Originally Posted by NskNsk View Post
    Thanks.
    Yes that is the only way you have to trick the door prox switches
    Mactec54
    Apr 2018
    9
    I put a separate stick on the door switch of my old VF-2. It's inside the slot all the time and I can open the doors during work if necessary. Of course, I don't open them during milling, but sometimes this option is good.
  1. Rotate spindle while door is open
    By NskNsk in forum Haas Mills
    Last Post: 05-27-2020, 06:02 PM
  2. Door won't open
    By stevemay55 in forum Hardinge Lathes
    Last Post: 10-27-2016, 02:38 PM
  3. Replies: 0
    Last Post: 04-26-2016, 12:21 PM
  4. Replies: 8
    Last Post: 04-04-2015, 02:59 AM
  5. 2216 FX Run spindle with door open???
    By Chuck Pressure in forum Fadal
    Last Post: 10-26-2009, 03:26 PM
