585,752 active members*
4,080 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Suggestions for new spindle - 24,000 2.2kW, ER20
    Apr 2005
    629
    Greetings,
    I am planning to finally replace my Chinese made 24,000 RPM spindle. It has served me well and is still running but getting a bit more noisy and running a bit hotter. The type I have is 24,000 RPM, 2.2 kW, ER20 collet, Air cooled. I bought it as a "kit" with mount and VFD.
    I am looking for a direct replacement and years ago I recall Rattman or Ratmotor being the vendor of choice but not sure who the good players are these days. Does anyone have recommendations?
    Thanks!
    Chris D
    Quote Originally Posted by Chris D View Post
    Greetings,
    Thanks!
    Chris D
    It would be easy to replace the bearings. There should be info on your specific spindle that indicates the how many of each bearing needed.
    You'll find either a total of three or four. They can be found on Amazon and AliExpress. There are videos on YouTube on how to do it.
    My 2.2kw air cooled spindle uses 4pcs Bearing (2pcs 7005+2pcs7002). I got the info from ebay. Those are very likely the same bearings you need, if same quantity. Ignore any with an alphanumeric ending like "a" or "ac". Keep in mind that the cost of the bearings has a lot to with longevity and runout.
    Anyway, that's my opinion.
    15362
    Re: Suggestions for new spindle - 24,000 2.2kW, ER20
    Greetings,
    Thanks!
    Chris D
    The quality is all about the same in the low-cost range
    You still should be able to find the same spindle motor, some have a different name but are in a lot of cases made by the same manufacture, is yours a square spindle or 80mm round
    Rattman spindles have never been a vender of choice
    Mactec54
    Apr 2005
    629
    Mine is the 80 MM round air cooled. As memory serves me, the propaganda sales literature said it contains 4 bearings. I did find something that looks exactly like it on Amazon.
    Chris
  1. 110v CNC Spindle 80mm ER20 Suggestions
    By Sandow12 in forum Spindles / VFD
    Last Post: 09-14-2022, 08:08 PM
  2. Replies: 14
    Last Post: 02-15-2019, 01:49 PM
  3. Replies: 1
    Last Post: 05-04-2017, 12:06 PM
  4. Replies: 1
    Last Post: 12-01-2016, 05:34 PM
