585,604 active members*
3,272 visitors online*
Thread: Fanuc 21i TB
Results 1 to 6 of 6
    Sep 2005
    272
    Fanuc 21i TB
    Trying to get load meters on the program check screen, this is a doosan lathe, anybody know what parameter 3100 bit 5 is (mon) ? the control has it but the parameter book does not show it? I have turned this on, on a 21i TD control but don't remember what parameter that was. thanks
    Dec 2009
    952
    Re: Fanuc 21i TB
    check parameter 3111.5 for operation monitor screen display.
    Sep 2005
    272
    Re: Fanuc 21i TB
    will do, thanks for the reply
    Sep 2005
    272
    Re: Fanuc 21i TB
    Nope that's not it, maybe this tc control don't have it?
    Re: Fanuc 21i TB
    I think you are looking in the wrong place. If you turn on Parameter 3111#5 then you have to press the "Position" function key then the far right softkey (The continuous button) Then you will find the loads as you described. I believe when you saw them on the program check screen it was a custom page done by the MTB.
    Sep 2005
    272
    Re: Fanuc 21i TB
    I think your rite, 3111.5 was already on and I do have the load meters on the pos page so custom from MTB.....I'll buy that. thanks for you help.
    Best Regards
  1. Fanuc tape cut mate fanuc om paramter setting for cutting materials
    By Vijay040engg in forum EDM Discussion General Topics
    Last Post: 08-27-2019, 10:00 AM
  2. Replies: 5
    Last Post: 04-20-2019, 02:31 PM
  3. Replies: 12
    Last Post: 12-26-2016, 10:31 PM
  4. Replies: 8
    Last Post: 09-25-2014, 02:58 PM
  5. Replies: 0
    Last Post: 01-28-2014, 04:41 AM
