Hello all.
Is it possible to jog the motors in mach3 demo version. Thanks in advance.
Hello all.
I think so, you have to set the HotKeys as I recall.
Jim Dawson
Sandy, Oregon, USA
if jogging is enabled it is certainly possible to jog....wouldn't be much of a CNC solution if it didn't.
Craig
I believe Mach3 demo jogs exactly the same as the licensed one. Just install the program, configure ports/pins and use the arrow keys for jogging. No hotkeys required.
Or did you mean something else like using a jog wheel controller?
As I understand, "3040T machine" can mean pretty much anything in Aliexpress-speak, so the video you found is not necessarily relevant.
If it has a USB controller, make sure you have the correct Chinese USB driver for that particular controller. Ask the seller where to download one if it did not come with the machine.
