585,977 active members*
3,966 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > wiring spindle to mx4660
Results 1 to 2 of 2
    Dec 2017
    5
    i recently purchased a mx4660 from www.steppermotorcanada.ca. i am very pleased with my purchase. i have installed it and in the process of configuring it. i have a few questions:
    • concerning the wiring for the spindle, i am not certain i understand the correct procedure about "jumping the wire" i have a two lead wire from the driver of my spindle which is jumped, but i have not jumped anything on the mx4660 side because i am afraid of damaging it. the spindle is not engaging. here are two pictures, one of the driver side, and the other of the 4660 side:
    • my next question is about the dip switches for the current to the stepper motors (model 23HS2430B) at 3 amps. they can run hot. i was told that i could set the dip switches to a lower value to reduce the heat. what value do you suggest?
    jacques
    [email protected]
    May 2015
    38
    Re: wiring spindle to mx4660
    Hi Jacques, I replied your email before, as below...
    I checked your spindle DDBLDV 1.0 manual that it can be controlled by external analog input as motor speed control.
    However, its voltage 5V outputs is a little low for mx4660 "+10vdc in" but you can have a try .
    DDBLDV 1.0 side MX4660 side
    "5V " connected to " +10vdc in"
    "VE" connected to "0-10v out"
    "GND" connected to "EGND"
    The pin14 (PWM)/pin25(GND) of DB25 on mx4660 is used for receiving PWM signal to control analog signal (voltage) output to your DDBLDV 1.0 for motor speed control.
    Refer to page 10, [COLOR=inherit !important]http://www.leadshine.com/UploadFile/...4660d_V1.2.pdf , pins instructions.[/COLOR]
  1. Gryphon - MX4660 - Mach 3 - Huanyang VFD and spindle
    By evilusions in forum Commercial CNC Wood Routers
    Last Post: 03-10-2020, 03:37 PM
  2. Comments/thoughts on MX4660 wiring
    By ahacking in forum Leadshine
    Last Post: 01-06-2018, 11:10 PM
  3. MX4660 + wj200 wiring question - I'm SO close
    By blitz355 in forum CNC Machine Related Electronics
    Last Post: 06-22-2017, 03:41 AM
  4. Spindle Relay Control with Mach3 and MX4660
    By icecats in forum Mach Software (ArtSoft software)
    Last Post: 06-06-2017, 12:29 PM
  5. help please with spindle wiring
    By anthow in forum DIY CNC Router Table Machines
    Last Post: 09-18-2013, 09:53 PM
