585,760 active members*
4,061 visitors online*
Results 1 to 7 of 7
    Mar 2005
    59
    Where to lift up IH ?
    I get tomorrow my machine, it´s not IH but it is same type.
    I need lift up it to the table, but I don´t know where and how ? Where I should put my lifting ropes... Have anyone pictures from lift up IH ?
    Thanks for your help.
    PS. Someday it is CNC-machine...
    Nov 2004
    42
    Juka
    I don't have any pictures (I was busy at the time). When I lifted my RF40, I wrapped a 3" cargo strap around the head and the post to lift. I placed the hook from an engine hoist right behind the motor. This balanced well because the CG was just below the head.
    Feb 2005
    29
    Here's one way I did it:
    Later I just took a short cut and put a loop of rope around it's "neck". Locked the Z gibs just in case, and lifted. Move the y axis around a bit and you can almost lift level.
    ciao
    lino
    Aug 2006
    97
    Please...study that photo and ask yourself where is the center the weight will rotate around if the machine tilts? (We lift heavy things...a lot!)
    Way too low under the table unless steps are taken to secure the top of the weight such as several turns of line around the column and motor and the suspending lines.
    If you must lift it monolithically do as the chap suggested and lift from the column and motor/head juncture with it run to the top.
    Better still do it piece meal
    Feb 2005
    29
    Quote Originally Posted by QSIMDO View Post
    This is a good point and I thought I recalled doing something to that effect when I roped it up. Sure doesn't look like it in the picture though.
    Perhaps I should remove the pic?
    ciao
    lino
    Dec 2005
    390
    I simply put a couple of rated lift straps around the collar of the head with the head lowered as low as possible and locked. Seems pretty stable and balanced. Please note this is on the older style (like in the above picture) and perhaps is not suitable on the new style. Watch your fingers and don't rush.
    Mar 2005
    59
    Thank you for good advices, machine is inside now and stand on table.
    That is nice machine!
  1. Router lift project
    By Corruptor in forum Linear and Rotary Motion
    Last Post: 08-11-2010, 03:40 AM
  2. BP Knee air lift assist?
    By DennisCNC in forum Bridgeport / Hardinge Mills
    Last Post: 03-26-2007, 12:31 AM
  3. HF or Lift Arc Start for TIG
    By kramerda in forum Welding Brazing Soldering Sealing
    Last Post: 03-03-2007, 08:15 PM
  4. Lathemaster power lift
    By outlaw paintbal in forum Benchtop Machines
    Last Post: 06-24-2006, 09:44 PM
  5. Concern with gantry lift
    By CuttersCov in forum DIY CNC Router Table Machines
    Last Post: 02-18-2006, 02:30 PM
