Re: Gully's new 3x3 steel CNC router build
Hi Gerry,
Thanks for the compliment.
Still using the old tried and true method that I used on my Joe's
I have cut and pasted the how too from that thread. It's really all in the prep work.
Secrets to getting a great finish on MDF. Spray paint it or use a good quality roller with the following methods to suit.
1: Skim the cut edges with a filler. I just use a pollyfiller skim coat type material and when dry sand it back well with a block (this is important as it fills out the little dips that router cutting leaves)
2: Seal the edges properly. There are a couple of ways to do this, I spray mine with a MDF clear high build sealer Its a commercial product used in furniture making to fill out grains, seal edges etc. The other option is to use a hi build easy sand acrylic undercoat and brush or roll it onto the edge then sand smooth.
3: One coat of sealer is not enough refer back to step 2 and repeat until sealed
4: Now prep everything and undercoat entire piece using above methods and /or materials and sand properly when dry.
5: Apply top coats
6: stand back , drink beer and admire your professional looking paint finish
It never fails to look good:cheers:
Gully
Striving for medeocrity..and achieving high scores!
