I have just bought a Startrite 502 bandsaw here in the UK. Its 3PH but I need it to run on single phase 220v. I've programmed a couple of inverters for 2.2kw spindles running at 400htz but after wiring up and programming the Huanyang its very underpowered so something is wrong. Prior to installing the vfd I changed the motor wiring from star to delta and when switched on rotates in the correct direction. I should in hindsite have factory reset the inverter when I got it as it says in the instructions but I will do now as I wish to start again with the programming.
My question is what are the Huanyang perameters to set for my motor or does anyone have a link to a similar set up?
The motor is stamped
Kw : 1.5kw
Rev/min :1420
V: 220-240v/380-415
Hz: 50
A 6.4-6.8/3.7-3.9
Not sure if this is 2 or 4 pole!?
Attachment 445606
