585,898 active members*
5,195 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Extrusion, spindle motor, linear rails, ball screws, steppers and drivers
    Jul 2019
    8
    ALBUM WITH PICTURES: https://photos.app.goo.gl/6QvBk7NLPQk2L1Wx6
    From my craigslist ad:
    I have quite a bit of new and used parts that would be perfect for a CNC router, plasma table, ect... I need to cut down on the amount of parts in my shop. They are listed separately but will consider offers for everything.
    - 2.2kw spindle motor, wired up just to test functionality, comes with 4m power cable: $150
    - 2010 x 1m ball screws with mounting blocks and ball screw nut mount block: $100/ball screw and brackets, 2 available
    - 20mm rexroth rail with two carriages per rail. These are new takeoffs from a machine, but are in great shape: $100/rail and carriage set, 4 available
    - DM542T stepper motor drivers. These are used but work perfectly: $20/driver, 3 available
    - 425ozin Nema 23 Stepper motors and drivers, NEW: $40/Stepper and driver, 2 available
    80mmx80mm Rexroth aluminum extrusion with brackets and hardware. $500
    - 4x 33''
    - 1x 39.5''
    - 3x 45.875''
    - 4x 49.5''
    Comes with 26 corner brackets, 4 floor anchor brackets, 4 leveling feet with mounts, caps for the corner brackets, and a whole lot of bolts and nuts. Note these are the drop in hammer nut stud type fasteners, not the bolt and nut type. It makes assembling the table much simpler.
    Attached are pictures of possible table configurations
    Located in Charlotte, NC
    Jun 2014
    5
    Re: Extrusion, spindle motor, linear rails, ball screws, steppers and drivers
    Is the spindle motor available? do you have a VFD for it?
    Jul 2019
    8
    It is available, I do not have a vfd that I am selling though.
  1. In progress - 8020, linear rails, ball screws, steppers
    By stevespo in forum CNC Wood Router Project Log
    Last Post: 07-25-2012, 05:10 PM
  2. Home made table, with linear rails & ball screws
    By nateman_doo in forum Benchtop Machines
    Last Post: 05-09-2011, 04:37 AM
  3. Chinease ball screws an linear rails
    By MaxTheModder in forum Want To Buy...Need help!
    Last Post: 01-08-2011, 10:44 AM
  4. Ball screws & linear rails.
    By diyengineer in forum Want To Buy...Need help!
    Last Post: 03-10-2010, 02:56 AM
  5. WTB: BALL SCREWS-LINEAR MOTION-STEPPERS
    By muddobber76 in forum Want To Buy...Need help!
    Last Post: 01-05-2009, 02:30 AM
