Hello.
I have a Router with an MK3 controller.
I would like to use the "AutoReturn" Feature after tool Change. The problem is that "AutoReturn" returns to the Machine position before the Tool Change procedure. When I switch from a small end mill to a longer end mill the machine may plunge directly into the workpiece after the tool change (depending on length of the new end mill end safe hight). I would like to AutoReturn to the Work position (which then includes the new tool length).
Is it possible to change this behavior?
