585,761 active members*
4,194 visitors online*
    Help problem with lathe threading. Siemens 808d turning
    I have owned this lathe for just over a year, and was trying to find a good PP for it. All was fine until I came to the threading cycle. I just could not get it to thread. So I went to the controller (Siemens 808d) and entered the Cycle 99 and then ran it. At 10 RPMs I could the threading tool would go to correct threading depth then rapid to the end of the cut and start the cycle again. I am new at CNC so I don't have a lot to draw on. I was threading with it about 2 month ago and it was fine. I even took the same post and ran it again and got the same results. Have any ideas?
    Feb 2011
    353
    Re: Help problem with lathe threading. Siemens 808d turning
    can you post the program for the threading cycle
  1. Post processor Solidcam / Siemens 808D turning
    By blaine.neal in forum Post Processor Files
    Last Post: 05-17-2023, 10:45 AM
  2. Post Processor for Siemens 808D lathe?
    By NJC in forum Autodesk CAM
    Last Post: 01-21-2018, 02:13 AM
  3. Siemens 808D - compatible CAM
    By hacklordsniper in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 09-05-2015, 11:27 AM
  4. CNC Lathe : OD threading turning = thread entry burr problem
    By ghettosled in forum MetalWork Discussion
    Last Post: 10-02-2009, 07:26 PM
