585,987 active members*
4,623 visitors online*
Results 1 to 6 of 6
    Jul 2020
    Laser won't turn off always on and no power control
    Hi community, so i bought an used cnc with laser for engraving, I have no information on the product, but i tried testing laser first using lasergrbl software. I tried to print a small stencil pick (10x10cm) but on the white spots of the pic the laser won't turn off, its always on and burning, it has 3 connector pin, gnd, 12v, pwm, i turn the button on the laser on, and it starts burning the wood.
    What am i doing wrong?
    Thank you
    Dec 2012
    192
    Re: Laser won't turn off always on and no power control
    Hello.
    Have you considered that the laser driver might be damaged?
    When you first turn the laser on power is applied to the driver but then on a signal to the driver shuts the control element off or on according to the program.
    If the only way to turn the laser off is turning the machine off it´s quite likely the laser driver is shorted. Most probably a MOSFET is used as the control element and you will require to replace it. You may need a service technician to do it.
    I hope this helps.
    Regards.
    Jul 2020
    How can I replace the board if the laser has no brand indication? can I plug any board?
    Dec 2012
    192
    Quote Originally Posted by jpnm24 View Post
    Hello.
    As far as I know the driver and tube are "married" together. You may have to ask the tube manufacturer for replacements.
    Yet the option of having a service technician take a look at the driver might prove worth the time.
    Regards.
    Apr 2010
    28
    Post pictures of your machine. Someone may be able to identify it and help you. Otherwise no one really can help you easily.
    www.picengrave.com
    Jul 2020
    Quote Originally Posted by citrusguy View Post
    yeah please cause i have same problem
  1. Where can I buy laser power control board for 40w MoshiDraw laser machine
    By azit in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-02-2016, 09:48 PM
  2. Mazak L Plus laser error 017 Power control limit!!!
    By contrabas in forum Laser Hardware
    Last Post: 08-24-2016, 09:39 AM
  3. Mazak L Plus laser error 017 Power control limit!!!
    By contrabas in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-24-2016, 09:36 AM
  4. how to control the power of a co2 laser
    By mark.a in forum Laser Control Software
    Last Post: 01-21-2016, 08:19 AM
  5. Replies: 0
    Last Post: 10-16-2007, 03:46 AM
