585,712 active members*
4,024 visitors online*
IndustryArena Forum > Maintenance in General > SERVICE FOR CNC-MACHINES > Abnormal Program Termination at start up
    Question Abnormal Program Termination at start up
    What we have is a,
    Anilam 5000M-3X
    Serial: 1129595216
    D of M: 2005
    PC Firmware version: 3.21A
    DSP Firmware version: 2.50X-5
    DOS version: 6.22
    Problem encountered: At boot up memory check clears, finds bootable section on C: drive, Starts ROM DOS, Software option screen comes up, <Select> control software,
    Abnormal Program Termination: Memory Protection Fault
    CS:EIP= 000CH:00047C04h
    C:\P5M> Divide By Zero
    We have replaced, in steps, the CMOS battery, reconfigured BIOS, reinstalled the last machine configuration, changed the RAM with new, scanned the hard drive for errors and at each step we still get the same message every time. 5 and 12 volt power checks out good.
    And on two occasions we have observed the following message after a reboot:
    ROM DOS Fatal Error, Memory Corrupted
    Any Ideas????? Thank you
    Re: Abnormal Program Termination at start up
    I have narrowed it down to external cache memory has failed.
    OK so the thing got a new CPU put in it, BIOS set, and Configuration file loaded.
    System boots up without error.
    But now two axis, X and Y run away. Z holds fine and is steady.
    No manual pulse generator control but manual jog buttons work with Z.
    Alternated X and Y to Z's amplifier, still runs away. And the tach wires.
    Can get X or Y to hold steady using the balance function of the motion set up and testing.
    But as soon as I put back in manual she's running away again.
    So I have eliminated the servo and amp as probable cause.
    DSP board?
    Getting back to this.
    Nope, what I thought was a saved configuration, was actually factory copy of the program. So it was an OEM installation from that point forward.
    Jun 2019
    10
    As a fellow anilam owner, this was an interesting thread to follow.
  1. RS-232 Termination string for Centurion V on a Partner I
    By dukejavelin in forum Milltronics
    Last Post: 05-20-2013, 01:43 PM
  2. Z axis termination
    By jrsaw27 in forum DIY CNC Router Table Machines
    Last Post: 08-02-2011, 12:38 PM
  3. Reinshaw RGH41 linear encoder limits termination
    By rainman in forum Servo Motors / Drives
    Last Post: 12-05-2010, 10:03 AM
  4. Need to start in the middle of my program
    By tjatdrilltech in forum Haas Lathes
    Last Post: 09-13-2010, 03:28 PM
  5. NEED HELP!alarm 44-12 APC START ABNORMAL
    By wilfrid in forum Cincinnati CNC
    Last Post: 12-08-2008, 10:37 PM
