585,931 active members*
3,702 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > DynaTorch > ARC Voltage showing all +++ instead of --- when idle
    Dec 2005
    504
    Something has gone haywire in the old Dynatorch. After homing the machine the arc voltage spirals up and displays +++. It starts at ??? > 125 > 181 >219 > 244 > +++. When run it pierces normal and then scrubs the torch into the plate. The voltage is stuck on +++. I seem to recall it always displaying --- when idle. Same issue with the plasma on or off.
    It appears the there may be an issue with the isolation board. See the attached image.
    Does anyone have any schematics of the controller?
    Attachment 445832
    Dec 2005
    504
    Re: ARC Voltage showing all +++ instead of --- when idle
    After tracing the arc voltage back through the controller I realized it was going back to the Z axis smart motor. Upon inspection it appeared the inline ohmic touch dongle had been hit by something. I removed it and now the software shows --- as normal. I'm back up and running.
    Now I need to sort the ohmic touch but I could live without it.
  1. High voltage power supply, low voltage perihperals
    By feechl in forum CNC Machine Related Electronics
    Last Post: 01-07-2014, 02:12 AM
  2. Precix 9100 Controller - VI voltage issue Voltage range only 6.5 to 10Volts
    By wdysf150 in forum Controller & Computer Solutions
    Last Post: 08-15-2013, 08:24 PM
  3. VSD-XE Overheating at idle
    By legendboy in forum CNC Machine Related Electronics
    Last Post: 12-09-2012, 04:09 AM
  4. Z load at 60% idle
    By dfearnow in forum Haas Mills
    Last Post: 06-21-2012, 04:41 PM
  5. Idle machines
    By MTSS Service in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-08-2009, 06:33 PM
