Hello everyone, finally getting to mess with the used 1204R we bought a few months back.
I'm running Fusion 360 for CAM and Mach3 for the sender.
Preview in Mach3 looks great, but I'm having an issue where when the router is done machining and moving to the next area to machine (above surface) it will stop before getting to the point where it's supposed to be and then start machining the toolpath. It's like it missed steps.
I thought maybe my rapid or feed was too high for the machine so I backed it down to 80ipm but I'm still having the problem. The first time I had this problem, I tried cutting the same part again on a different spot on the table and it happened in the same area of the part as the previous one. I changed from adaptive clearing to pocket toolpath on the next try and it then had the same issue on a different part of the toolpath, all of these have been issues with the rapid movement even though it's down to 80ipm.
Last try it made it through all the pockets and clearing and then happened on the way to start the contour toolpath.
Any ideas?
