585,931 active members*
5,275 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > DIY Precision Black Granite CNC Machine from surface plate.
    May 2007
    7
    I have started building CNC machine from black granite surface plate.
    Dimensions of surface plate: 650x750mm
    Working area of finished CNC machine: 200x200x100mm.
    Used and worn surface plate was used for this project.
    Below you have a movies about building my CNC machine from black granite:
    https://youtu.be/bkmn34lKe_E
    https://youtu.be/sbincod2e3c
    Dec 2012
    192
    Re: DIY Precision Black Granite CNC Machine from surface plate.
    Hello.
    One question. Did you gave the base any treatment or directly painted it?
    Regards.
    May 2007
    7
    Quote Originally Posted by BBMNet View Post
    Hello.
    Regards.
    It is black granite surface plate. It was not painted.
  1. DIY Precision Black Granite CNC Machine from wiem surface plate
    By kris79 in forum Drilling- and Milling Machines
    Last Post: 07-01-2020, 08:23 AM
  2. Precision Black Granite Surface Plate
    By nateman_doo in forum Benchtop Machines
    Last Post: 02-12-2011, 08:28 PM
  3. Granite or steel surface plate for machine base?
    By will gilmore in forum Vertical Mill, Lathe Project Log
    Last Post: 02-07-2008, 04:12 AM
  4. Cleaning Granite Surface Plate?
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 02-01-2006, 07:09 AM
