585,927 active members*
3,954 visitors online*
    Aug 2018
    29
    Problem loading Gcode on new Mach4 machine
    Putting together a 3 axis gantry mainly for engraving. Mach4(demo), ESS, Gecko drives. Got motors tuned & calibrated but when I try to load any of the demo gcode files I get
    "a macro failed to compile while loading"
    What am I missing?
    cncneon
    Apr 2004
    5737
    Re: Problem loading Gcode on new Mach4 machine
    Try redownloading and reinstalling the Mach4 software; it sounds like something got corrupted.
    Andrew Werby
    Website
    Aug 2018
    29
    would you install over the existing copy or do an uninstall, clean registry, then a fresh install?
    And how about the ESS, fresh install on it also?
    Also my profile, should I save it or start afresh?
    cncneon
    Apr 2004
    5737
    Quote Originally Posted by cncneon View Post
    [Do a clean install, but save the XML profile using a new name .]
    [Sure, why not?]
    cncneon
    [Save it. If it turns out to be a problem with the profile, you can always build another one from scratch, but that's more work than saving and editing the one you've got, if it's any good.]
    Andrew Werby
    Website
  1. 5 Axis Gcode Interpreter for Mach4
    By ChristianLL in forum Mach 4
    Last Post: 09-03-2016, 12:52 PM
  2. Mach3 autozero issues after loading GCode
    By daybowbow in forum Mach Software (ArtSoft software)
    Last Post: 11-08-2014, 11:35 AM
  3. mach3 not loading full gcode
    By shiv15uk63 in forum Mach Software (ArtSoft software)
    Last Post: 04-09-2013, 01:48 PM
  4. Replies: 4
    Last Post: 03-22-2011, 02:05 PM
  5. PROBLEM IN LOADING MACHINE DATA FROM PAPER TAPE READER
    By FAHJ in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-06-2010, 09:04 AM
