585,728 active members*
4,960 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OSP5020m DNC-B Baurate
Results 1 to 6 of 6
    Nov 2012
    4
    I have an OSP5020M with Dnc-B as baurate 4800, I want up to 9600 please help me ..... thanks
    Apr 2009
    1262
    Re: OSP5020m DNC-B Baurate
    You should be able to change Parameter word #39 to 9600 if using channel 1. Be sure to wait for about 2.5 minutes for backup to occur automatically and the power down including the breaker for 1 minute to let the RS board reset properly.
    Best regards,
    Experience is what you get just after you needed it.
    Nov 2012
    4
    Quote Originally Posted by OkumaWiz View Post
    Best regards,
    I change the parameter #39 to 9600 and backup (F7),=> restarted ... Everything has not changed...works only at 4800
    Apr 2009
    1262
    Then I would suspect that you are not using channel 1. Check your word#43 parameter to see what it is set to. I believe that is designating which port DNC will use. If 0 then using channel 0 and so forth. If 0 then try setting baud on word#6. Channels 2,3,4 are Word 40,41,42. Change the appropriate one as described before.
    Best regards,
    Nov 2012
    4
    Best regards,
    I did but the system still doesn't work at 9600.. (#6 9600, #39~42 9600, #43 0)
    Apr 2009
    1262
    Did you follow my exact instructions about powering down with breaker off for 1 minute?
    If you did then go to the parameter mode on the machine and type in CMPS and tell me if some “magic” DNC parameters open up.
  1. Okuma mc-4va OSP5020M - dnc - new to cnc
    By Thoreng in forum Okuma
    Last Post: 02-10-2019, 10:08 AM
  2. Okuma MC 4VA OSP5020M
    By Patoruzo in forum Milling
    Last Post: 11-15-2016, 04:27 PM
  3. OKUMA OSP5020M HELP
    By KENNY D in forum Okuma
    Last Post: 05-18-2014, 04:12 AM
  4. MC-500H osp5020M - 139 alarm A
    By cnc312 in forum Okuma
    Last Post: 09-11-2013, 08:53 PM
  5. need osp5020m manuals
    By guydrisc in forum Okuma
    Last Post: 11-01-2010, 05:48 AM
