585,567 active members*
3,434 visitors online*
    First CNC, First post, Need advice.
    Hello All,
    I have been dreaming of a cnc router for years and years and recently came across an opportunity to buy one in an abandoned storage locker. Included in the locker was a Wart Hog Sx100 and remnants of what looked like a sign shop. Unfortunately not everything for the CNC was included, it did not include a PC or any tools, bits or accessories. I got the storage pod delivered to my house, and we got this behemoth of a router (60"x123" footprint) out and into my garage. I've inspected the components/wires/parts and after comparing them to the original spec sheets, it appears this unit has been upgraded.
    Within the power supply housing is a Gecko G540, a Keling KL-600 48v power supply and various wries/cables, one leading to a Delta VFD.
    The X and Y step motors are VEXTA pk296-f4.5a
    I ordered an older Win 7 32bit pc with parallel port to run the machine fron Mach3, but have since abandoned the parallel port plans because of the Windows updates and drivers, etc. Because of that I also decided to go with Mach4 since I was no longer pigeon-holing myself into older tech.
    ***Here's where (I think) I need help.***
    I need a motion controller. I have narrowed it down to the Warp9 ESS and the UC400eth
    Will either of these suit my needs better?
    Are either of these inherently better or easier to install than the other?
    I'm sure I left out a ton of relevant info, I look foward to your help.
    Thank you in advance.
    Apr 2004
    5731
    Re: First CNC, First post, Need advice.
    Either one of those adapters should work.. That old PC would probably work too; you don't need to use it for anything else but running the router, so you don't need to deal with Windows updates (turn off the automatic update function entirely, since it just interrupts cutting). You don't need to install drivers either, unless you're using it for other things, which isn't recommended. But you'll get better throughput by using a newer computer and an adapter.
    Andrew Werby
    Website
    Thank you for your reply! I ordered the Warp9 ESS and it should be here early August. I'm still using that pc for sure, I bought it as a dedicated control pc and don't plan to load any other prgrams, I just went with Mach4 instead of Mach3. When you say better throughput with an adapter, what adapter am I looking for?
    Thanks!
  1. First post edit advice please.
    By btu44 in forum Post Processors for MC
    Last Post: 03-21-2013, 06:31 PM
  2. 1st post! looking for advice on dyna 2400
    By poorfarmer25 in forum Knee Vertical Mills
    Last Post: 09-13-2011, 08:43 PM
  3. First post - need some advice
    By orion63 in forum DIY CNC Router Table Machines
    Last Post: 12-27-2010, 10:44 PM
  4. Hello 1st post, advice on controller and software
    By NJC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-30-2008, 05:02 PM
