585,971 active members*
4,059 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > How to machining this corrugated pipe mold?
    Jul 2020
    Hi.please help me.
    How to milling this mold
    Attached Thumbnails Attached Thumbnails Screenshot_20200723-103023_Chrome.jpg
    15362
    Re: How to machining this corrugated pipe mold?
    Quote Originally Posted by Esta252 View Post
    Hi.please help me.
    Do you need to replace some segments or want to create a different profile I used to make them it's just done with a cutter to the profile that you want the blocks are heat treated, and quite often hard chromed there are some of the large pipe sizes that are cast in aluminum and then machined, you have to make them in matched pairs
    You could use a EDM as well to make them, but both lathe and milling is used to make them
    Mactec54
  1. Machining a mold from atp-5 vs other aluminum
    By QuinnSjoblom in forum Moldmaking
    Last Post: 08-01-2018, 08:57 PM
  2. Machining mold plastic
    By loveteenvn in forum UG NX
    Last Post: 10-13-2015, 03:29 PM
  3. Machining MOLD MAX HH
    By mxer in forum Moldmaking
    Last Post: 12-17-2009, 10:19 PM
  4. Machining or casting mold cavity
    By Thorpydo in forum Moldmaking
    Last Post: 04-22-2009, 07:32 PM
  5. uni-directional mold machining
    By HuFlungDung in forum DNC Problems and Solutions
    Last Post: 05-28-2003, 04:54 PM
