585,949 active members*
4,211 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Xcarve 1000mm x 1000mm cnc vs WorkBee 1500mm x 1500mm cnc ?
Results 1 to 6 of 6
    Jul 2017
    348
    hi im looking for some neutral input on these 2 machines only based on stock machine only and facts.
    which machine is better design and better value based on machine only
    i have made some compasrisons and please would like feedback.
    workBee ............................xcarve
    170oz steppers vs 128 oz steppers? disadvantage
    1300mmx1300mm vs 750mmx750mm? disadvantage
    1500watt VFD spindle vs dewalt router ? disadvantage
    2A drivers vs 4A drivers? advantage
    much heavier duty framing vs lighter duty framing? disadvantage
    increased Z travel vs decreased Z travel? disadvantage
    screw drive vs belt drive? overall disadvantage and not industry standard on better machines
    increased Z clearnace vs decreased Z clearance? disadvantage
    GRBL sontroller vs GRBL controller ? basically a tie
    24V power supply vs 24V power supply ? basically a tie
    $1500 cost vs $2000 cost retail? disadvantage
    ER11 collet design vs Dewalt proprietary collet? disadvantage
    workbee 1500mmx1500mm
    https://www.ebay.com/itm/Newest-1515...oAAOSw1SFfAEpZ
    xcarve 1000mmx1000mm
    https://www.inventables.com/technolo...IaAhM-EALw_wcB
    thank you
    May 2011
    790
    Re: Xcarve 1000mm x 1000mm cnc vs WorkBee 1500mm x 1500mm cnc ?
    The Workbee only has an 8mm diameter leadscrew. Kinda tiny. So they have some sort of tensioning mechanism on the leadscrew to prevent whip. Yeah, I have no idea what this is or how it's built. Makes it impossible to do a comparison.
    The larger extrusions and double the amount of wheels make the workbee more rigid....
    It looks like the "workbee" is made by a number of different places. The original ooznest workbee comes with a Duet 2 board, 32 bit, which isn't cheap, and is a nice board. The 2A limitation means that this board was meant primarily for Nema 17s, but you can get an expansion board to add higher current external drivers. None of this is relevant to you per se, as the link you've attached from EBay is a knock off that doesn't have this board.
    I'm not a fan of either of these machines. Check out this thread here if you haven't already....
    https://www.cnczone.com/forums/gener...y-machine.html
    For the same money as the X-Carve (my link shows $2299, not $2000) you could put together a CNC4Newbie machine, which would be better than either of the 2 choices you asked about.
    Jul 2017
    348
    Hi thanks but im asking for xcarve vs wotkbee knockoff only
    Yes workbee is much larger and has 4-8x more rigid rails those are fscts
    Yes 8mm screw drive..but screw drive is superior overall compared to rubber belts...thats a fact
    Do you see any advsntsges the xcarve has over the workbee ?
    Mechanically? ...do you disagree with any of my comparison list?
    The workbee is more than 2x the machining area compsred to the smaller xcarve
    There are thousamds of diy kits avsilable today..dime a dozen.
    But for this thread its xcarve vs workbee knockoff.
    For the same money as the X-Carve (my link shows $2299, not $2000) you could put together a CNC4Newbie machine, which would be better than either of the 2 choices you asked about.[/QUOTE]
    Jul 2018
    6335
    Hi Selby - Looking at your list and giving 1 point to the advantage side the Work Bee wins 9 to 1 so that's your answer. Peter
    May 2011
    790
    Quote Originally Posted by Shelby5041 View Post
    You're the one saying it's a fact. Not me.
    8mm diameter lead screw with a janky who knows what kind of tensioning system may or may not be better than a small rubber belt, I have no way of knowing. That's what I'm saying.
    Have fun with whichever you choose.
    According to this, Larger size Wokbee's are belt driven.
    https://openbuilds.com/builds/workbee-cnc-machine.5626/
    This is like asking what's better, a car with a blown engine, or a car with no engine.
    All of these low cost machines have serious rigidity issues, and they are all comparable. And advantage one would have would be minimal, and probably negated by some other issue.
  1. Internal grinding at Kell Varia-1500mm
    By fh261059 in forum Grinding
    Last Post: 02-08-2022, 05:58 PM
  2. Your thoughts on 1500mm X axis gantry design
    By disneytoy2 in forum Linear and Rotary Motion
    Last Post: 01-09-2019, 07:06 PM
  3. 1500mm 2010 gten ballscrew bent
    By Jon.N.CNC in forum DIY CNC Router Table Machines
    Last Post: 10-29-2015, 01:49 PM
  4. 1500mm X 1000mm cnc router-Please your advice
    By ba99297 in forum DIY CNC Router Table Machines
    Last Post: 04-30-2013, 10:40 AM
  5. 2400mm x 1500mm table what motors do i use ?
    By mr.j in forum Linear and Rotary Motion
    Last Post: 09-07-2010, 02:33 PM
