Handheld Laser Welding Machine
The handheld laser welding machine overturns the previous working mode of the laser welding machine, using the hand-held welding gun instead of the previously fixed light path. This operation mode not only facilitates the welding of products such as molds, advertising words, kitchenware, and so on but also makes outdoor laser welding possible.
Hand-Held Laser Welding Machine Characteristics:
The hand-held welding head is equipped with five meters of imported optical fiber, which is flexible and convenient and can realize outdoor welding.
The operation mode of the hand-held welding torch enables the workpiece to be welded at any angle at any part.
Dual light path intelligent switching, uniform energy distribution based on different time and different light.
Suitable for all kinds of complex welded joints and spot welding of various devices.
CCD camera monitoring system to facilitate observation and precise positioning.
Application Range of Handheld Laser Welding Machine:
It is widely used in the kitchen, household appliances, advertising, mold, stainless steel door and window, handicraft, home supplies, furniture, automobile accessory, and many other industries.
Advantages of Handheld Laser Welding Machine:
1. Suitable for small range production: Compared with the fully automatic equipment deployment, the handheld laser welding machine has much lower production obedience. But for the production workshops that deals in small-scale processing or non-large range welding, the manual laser welding is the best choice, there is no need to set up the equipment to deploy the welding table and little space taking, and the important point is that the welded products of the small workshop are diverse and the product shape is flexible, so the manual laser welding can totally satisfy the demand of this kind of production, and the compliance is better.
2. Low Maintenance Cost: Hand-held laser welding, no fine welding table, low material, and energy consumption, and low cost of equipment deployment and maintenance. Under the same working environment, we need to spend a lot of maintaining the welding table, but the welding can be done as long as there is a hand-held laser welding machine in the manual laser setting equipment deployment. As for a replacement, changing accessories costs low, if the customers don't know how to change, they can have direct maintenance from the manufacturers, don't need to worry about the delivery.
The handheld laser welder machine can also be used for mold welding, and the joint double-precision microscope can complete the detailed welding operation.
The handheld laser welding machine not only can hold the portable laser welding discussion but also can be used for high precision mold welding. It is the most cost-effective welding equipment deployment for many small range manufacturers.
