585,925 active members*
3,598 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Meldas 520 4th axis , cannot do more then 360 degree ALARM M1 operation error 0007
    Nov 2010
    8
    Hello friend !! I want to know if it is possible to make the 4th axis spin more then 360 degree ? it seem to stop at the home limit every time , cannot do more then a full turn , it like 0 to 360 and back to 360 to 0 .
    I have look at the hardware limit switch on the 4th axis and every thing is OK with a continuity test , 24v dc on the leads OK , Homing at start up OK , but with the MPG , JOG , MDI GCODE , M1 operation error 0007 at over travel ??!
    Is there a parameter blocking the 4th axis to be able to make it run freely with rotation 360 degree and more ?
    Thank for your reply !!
    Best regards
    Fred
    Nov 2010
    8
    Re: Meldas 520 4th axis , cannot do more then 360 degree ALARM M1 operation error 000
    Hello every buddy !! No one knows Meldas 520 ?? yes it is old but still working strong , still making my pay day. If there is someone that knows well meldas and can help who'd be very appreciated .
    Thank you and best regards
    Fred
    Mar 2021
    7
    Hello Evolution what amplifiers and what motors do you use ?
  1. MELDAS 64S M01 OPERATION ERROR 0004
    By CNC Machine OT in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-14-2021, 11:13 AM
  2. MELDAS 500, ALARM Z70ABS ERROR
    By godzila in forum Mitsubishi controls
    Last Post: 03-31-2014, 02:58 AM
  3. M32/H500/Alarm:323 pallet changer error operation
    By Karsue in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-07-2011, 07:06 PM
  4. M01 Operation Error 0101 on Mitsubishi Meldas M50 control - help!
    By SRT Mike in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-16-2009, 02:33 PM
  5. OUCH: 0.0007% Error rate not acceptable
    By Geof in forum Haas Mills
    Last Post: 07-02-2006, 04:09 AM
