585,974 active members*
4,359 visitors online*
    Feb 2019
    5
    Need help with Sinumerik subprogram
    I am trying to program a loop for broaching a keyway. I am making subprogram for that, but dont know how to program it correctly so I need some help.
    I am trying to program this:
    G0 Y-5 (comming to starting position)
    G1 Z-72 F3000 (broaching down with a feedrate)
    G0 Y0 (rapid to safe y position)
    G0 Z1 (rapid out to safe z)
    G0 Y-5.05 (rapid to next y position)
    G1 Z-72 F3000
    G0 Y0
    G0 Z1
    G0 Y-5.1
    So the question is how to write a cycle that goes to to the next y by he same amount (y-5.05 ; y-5.1 ; y-5.15; y-5.2 etc) for lets say 60 times. Of course I can write that manually, but maybe it is possible to write a cycle for that?
    Hope you understand the question.
    Aug 2009
    1573
    Re: Need help with Sinumerik subprogram
    ... use an Incremental move with Y say .1mm looped 10 times would be 1.0mm or what ever you like
    Feb 2019
    5
    Can you write an example how the code with incremental move should look like?
    Aug 2009
    1573
    ,,,here's one way might work for ya....format might not be correct...change as needed
    in the Main program Position your start point
    N100 G0 G90 X0 Y-5 Z1 (starting position) or what ever
    N101 BROACH Pxxxx (the P is how many times to repeat the sub program)
    N102 G0 G90
    N103 G28 Z0
    N104M30
    BROACH
    G91 Y-.05
    G1 Z-73 F3000 (broaching down with a feedrate)
    G0 Y.05(rapid to safe y position)
    G0 Z73 (rapid out to safe z)
    G0 Y-.05 (rapid return from safe y move)
    M17 or M99 (not sure for your machine)
  1. Sinumerik 840C, Sinumerik 840D
    By marek-vavra in forum SIEMENS -> Sinumerik 840C
    Last Post: 09-02-2022, 07:04 PM
  2. Subprogram
    By bcnu in forum BobCad-Cam
    Last Post: 04-08-2015, 08:02 PM
  3. LBL in subprogram
    By GreenVeltlins77 in forum HEIDENHAIN -> TNC
    Last Post: 12-10-2011, 04:29 PM
  4. subprogram
    By krow in forum OKK
    Last Post: 09-30-2009, 11:18 PM
  5. eia subprogram
    By rs1982 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-11-2008, 02:10 PM
