585,978 active members*
4,397 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Torchmate > ISO 401a or 501a Signal Generator
    Feb 2016
    50
    Anyone have a spare? I have an TM 3 I'm building back to life without any controls. I would like to stay with TM.
    Aug 2013
    15
    Re: ISO 401a or 501a Signal Generator
    I have an old 401A box from my machine if you are still looking for one. SN is 5518
    Dan
    Does either of you know if the smooth stepper can be substituted for the 401a signal generator in order to utilize the flash cut servo controller box and servos with mach3 or other controller software? I have a flash cut setup that was replaced by stepper motors and cheap drivers. I was thinking if plugging the step and direction outputs from the smoothstepper into the logosol drivers input if that would work.
    Feb 2016
    50
    I suppose you can disconnect the 501a board inside and connect in the Ess in to the drivers. A driver is pretty much simply controlled by step dir enable signals. I was actually trying to do the reverse using a 401a or 501a breakout to aftermarket drivers. I do have a mill, Router, plotter, and laser running off one machine with ess and mach3 runs great for each have different profiles. I tried 2 other breakout over the years. The ess is my last upgrade. I use very high pulse rates for servos. A lot for the servo spindle. The flash cut is great too. I just have a second plasma that needed controls. And didn’t find a used controller. So went with candcnc commandcnc for newest torch height controller for the money.
    Feb 2016
    50
    Quote Originally Posted by kitch940 View Post
    Dan
    I’m holding out to see how the commandcnc setup works for me. If I don’t like I’ll message again. I’m going to do a comparison. Sheet time, cut quality, and consumable wear.
  1. 501a signal generator question/problem
    By Jeonlyep in forum Torchmate
    Last Post: 02-19-2024, 01:29 AM
  2. Adding a spindle to 501A signal gen. What's needed/ How to?
    By modelaratrod in forum FlashCut CNC
    Last Post: 01-05-2020, 09:38 AM
  3. Replies: 1
    Last Post: 01-04-2017, 01:56 PM
  4. Replies: 3
    Last Post: 01-02-2015, 02:35 AM
  5. SIGNAL GENERATOR 501A
    By ecamacho in forum Torchmate
    Last Post: 01-18-2008, 10:57 PM
