585,991 active members*
5,080 visitors online*
    Oct 2012
    4
    G41 G42 not working
    I have a 1990 Bridgeport V2XT mill that I updated with an Allin1 control jan. 2020.
    My problem is I can not get cutter compensation to work. I have wrote a small code to test and changed it up a couple of different ways and no luck.
    I know you need to use a lead in line to start the compensation. Thanks for any help.
    ;tool offset
    T6 M6
    S1500 M3
    G40
    G20 G90 G17 G54
    G0 X-2 Y2
    G41 D6
    G1 X-1 Y1 Z.050 F20
    G1 X-1 Y0 Z-.100
    X2 Y0
    X2 Y-1.5
    X0 Y-1.5
    X0 Y0
    M25
    M05
    Attachment 446520
    Feb 2008
    280
    Re: G41 G42 not working
    What diameter value do you have in your offset library for D6?
    Oct 2012
    4
    .500"
    Oct 2012
    4
    I forgot to tell you, Iam a liar. HaHa.
    I put 1/2" in the tool library not the offset library. All is great now and the learning curve continues.
    CNCSNW thanks so much.
  1. G96 Not Working How it Should on T32
    By mbpp in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-09-2018, 08:07 PM
  2. Setting drills, ID tools and back working/end working tools
    By jonathan2jones in forum CNC Swiss Screw Machines
    Last Post: 04-22-2017, 01:11 AM
  3. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  4. Switch view between machine working enveloppe and job not working?
    By skillalot in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-10-2015, 03:55 PM
  5. Red dot not working
    By Dubliner in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-19-2010, 11:48 AM
