584,871 active members*
5,327 visitors online*
Results 1 to 7 of 7
    Mar 2005
    10
    Better Quality Limit Switches
    I have a homebuilt CNC router I've been using for about 3 years now (I think). I got some of the cheapie uxcell plunger limit switches off of Amazon and they work...ok. It would be nice to have a little better repeatability though. Haven't really tested, but I'm guessing these vary by 10-20 thou when you home the machine. Maybe little more, maybe little less.
    Anyway, when I look I seem to find only 2 types: junkie ones like mine or super expensive ones that repeat to 5-10 microns. Anybody found some affordable ones that might let me repeat home to around a thou?
    Wally
    Mar 2005
    10
    Re: Better Quality Limit Switches
    OK, I *did* in fact do a search before I posted, but didn't find anything. Then the similar threads list led me to some past threads. Based on those, the AAP2T35Z11 seems like a good candidate. Anybody used them? What kind of repeatability are you getting?
    Thanks again,
    Wally
    Jan 2009
    28
    Hall Effect switches ftw! Easy DIY project and cheap too.
    Nov 2007
    483
    What about the inductive type you find on 3dprinters for bed leveling. Super cheap, repeatable accuracy, and reliable.
    Jan 2009
    28
    This thread has everything you need to make your own, very accurate, Hall Effect limit/home switches: https://www.cnczone.com/forums/open-...cnc-forum.html
    Nov 2013
    4282
    I've been using these switches for years for limit and home switches. I get 0.02mm repeatability when used as home switches.
    https://nz.element14.com/omron-indus...a/dp/150034001
    Craig
    Balluff is a great deal to have very precise limit switches.
    Are used also in professional centers.
    https://www.balluff.com/local/us/productfinder/#/ca/A0001/cg/G0113/product/F01332/variant/PV146833
  1. Replies: 0
    Last Post: 04-08-2020, 03:52 PM
  2. Replies: 3
    Last Post: 11-05-2013, 02:54 AM
  3. E-Stop,Limit Switches - Car door open switches ?
    By TrickyCNC in forum DIY CNC Router Table Machines
    Last Post: 04-19-2012, 09:55 PM
  4. Good quality limit/home switches OR a fix
    By THend in forum Mach Software (ArtSoft software)
    Last Post: 11-06-2008, 03:33 PM
  5. Where to buy quality limit switches?
    By Mr.Nerd in forum CNC Machine Related Electronics
    Last Post: 11-30-2007, 11:19 PM
