584,849 active members*
4,538 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > My CNC machine will not read file with extension
    Sep 2011
    9
    My CAM software writes programs with an extension .NC at the end of the program number ( O1234.NC), My CNC machines will not recognize this when I am trying to upload it to the machine from a USB. I have been renaming the file with no extension and it works great. But now that I am using Windows10 I am having trouble renaming a file with no extension. Is there a way to get the machine to recognize the file with a .NC extension?? to avoid renaming all together
    Greg
    Dec 2012
    392
    Re: My CNC machine will not read file with extension
    Hi sir,
    Rename to O1234.txt, should work.
    The M198 command uses files without extension.
    regards.
    Aug 2009
    1567
    ...edit your Cam post process to Save as .txt (ANSI)
    Jan 2018
    1516
    Quote Originally Posted by gsmachinist View Post
    Greg
    Windows 10 simple to edit.
    Go to file explorer.
    At the top select 'view'
    Far right, check the box 'file extension'
    Now filer extensions will appear and can be edited.
    Quote Originally Posted by dazp1976 View Post
    Yes, this is the easiest way to solve this problem.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  1. ENG file extension
    By DDA1986 in forum Hobby Discussion
    Last Post: 10-27-2019, 10:07 PM
  2. milltronics file extension
    By blowncoupe in forum Milltronics
    Last Post: 12-29-2014, 07:38 AM
  3. Opening CDR file extension.
    By terry32506 in forum Uncategorised CAM Discussion
    Last Post: 03-02-2008, 05:53 PM
  4. post file extension
    By GRANDPA in forum Mastercam
    Last Post: 03-22-2007, 04:44 AM
