585,712 active members*
3,883 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Critique my fixed gantry router/mill design
Results 1 to 6 of 6
    Mar 2020
    179
    Looking for feedback on my fixed gantry router build. Goal: machining aluminum molds with high precision (+/- .002"), and trimming carbon composites at high RPM (hence router not mill). This design is heavily influenced by earlier discussion on this forum, but just want to check in before I proceed further.
    frame
    24" x 24" x 3" granite surface plate base
    8" x 6" x 1/2" steel gantry tube, machined, epoxy aggregate filled
    5" x 2" x 3/8" gantry supports- welded, stress relieved, machined, epoxy aggregate filled
    16" x 14" x 1" cast aluminum plate for table
    linear motion
    20mm medium preload linear rails - not hiwin but best quality chinese, fairly spendy
    1204 ballscrews driven 2:1 with GT5 belts
    Nema 34 steppers (leaving room for servo upgrade in the future if needed)
    Controller
    buildbotics control system
    Spindle
    yet to be determined, likely the spindle stocked by Avid CNC
    Have priced out every component and it should come in well south of $5K.
    Specific questions:
    -What about replacing the 1" thick z-plate with 10x2.25x1/2" aluminum C channel? Would add much rigidity and bring spindle closer to gantry. Do I have any hope in hell at machining the web of a C-channel flat and it staying that way?
    -Any drawbacks to 12 mm ballscrews? Screws are short so whip is not a problem here
    -Have 0.5 mm clearance over ballscrew mounting blocks. Clearance is clearance, right?
    -The y-axis table rails are mounted on ground flat aluminum bar. I'd prefer to mount the rails directly to the surface plate and put the spacers between the carriage blocks and the table as this would elimate issues of flatness with the ground bar. But elevating the rails would keep them from the water that will collect a bit on the plate (will drill drainage holes anyways). Pros and cons?
    Thanks so much!
    Attached Thumbnails Attached Thumbnails v2_frontview.png   v2_perspective.png   v2_sideview.png   v2_topview.png
    Mar 2020
    179
    Also all connections are through bolted, holes and fasteners just not modeled yet. Largest reasonable fasteners used for every application
    May 2011
    790
    Re: Critique my fixed gantry router/mill design
    Quote Originally Posted by catahoula View Post
    So I assume that's the amount of travel you want, 16" x 14"....
    12mm ballscrews and Nema 34 motors are a mis-match IMO. You're going to break something.
    4mm lead ballscrew (4mm per rev?), with 2:1 gearing, so you want to make the screw turn twice as fast as the motor?
    Just go with 20mm diameter, 10mm lead ballscrews (1:1, no gearing). If you use servos later, you can use a 3:1 belt driven gear reduction (so the servo spins faster than the screw).
    Other than that, it looks like you have a decent conceptual design.
    If it were me, I'd consider a complete redesign using surplus linear stages with leads of 10-20mm in X and Y, and perhaps a dual column rising gantry with moving table. That would add a some extra complexity to it while at the same time making it easier to build. At least that's what I'd do. Not saying it's wrong to do it your way.
    Oct 2005
    73
    Consider a brace like the one I've expertly drawn in red in MS paint. It will greatly increase the rigidity in that direction for minimal weight gain.
    I'd keep the 1" Z plate but consider adding braces on the side of it to stiffen it up, shown in yellow, if required
Name:	v2_perspective - Copy.png
    Mar 2020
    179
    Thanks, will consider braces. The z axis brace is what I was getting at with using a c-channel instead of plate, but bolting on braces like you suggested may well be simpler/easier to machine flat.
    Quote Originally Posted by jones View Post
    Mar 2020
    179
    Thanks-
    12mm ballscrews was based on keeping a low profile so the gantry and table don't need to be excessively high. I'll look into load ratings.
    Rising gantry is definitely cool, but I want to keep the axes guaranteed perpendicular without needing to reference off limit switches.
    Quote Originally Posted by NIC 77 View Post
  1. Replies: 16
    Last Post: 08-22-2021, 01:41 AM
  2. Fixed Gantry Design
    By CatalystGilles in forum DIY CNC Router Table Machines
    Last Post: 06-05-2018, 06:18 PM
  3. Need help - Fixed gantry design
    By boltzzz in forum Mechanical Calculations/Engineering Design
    Last Post: 01-01-2018, 03:14 AM
  4. Welded Fixed Gantry Router/Mill
    By robotmickey in forum Benchtop Machines
    Last Post: 11-19-2017, 06:56 AM
  5. Hybrid Design - Fixed Gantry Router for High Speed Aluminum Milling - Metal Nibbler 5
    By Bob La Londe in forum Uncategorised MetalWorking Machines
    Last Post: 04-10-2014, 05:16 PM
