585,898 active members*
5,405 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Feb 2012
    17
    SVG to G-code converter
    Hi guys, I'm making the converter SVG to G-code:
    https://veiseliha.com/#more-demo
    It uses SVG syntax described here:
    https://veiseliha.com/layered-svg-tutorial
    Will appreciate any help in testing it, especially if you use anything another than LinuxCNC
    Dec 2012
    192
    Re: SVG to G-code converter
    Hello.
    Unfortunately localhost is unable to open.
    It would be interesting to try your program.
    Regards.
    Dec 2003
    1222
    This could be a useful development.I know that Inkscape has the capability to create Gcode from an svg file but have never found a way to make it happen,if there was a contest for the least intuitive program ever I believe Inkscape would be a contender.
    Feb 2012
    17
    routalot
    I tried Inkscape G-code plugin but without any significant success, I rather want to have online tool, hope it will be useful not only for me.
    Feb 2012
    17
    35538
    Like this?
    https://www.makercam.com/
    Feb 2012
    17
    Like this?
    Not working for me Just seen "about this..." line.
    Attachment 446652
    May 2005
    1662
    Quote Originally Posted by C_N_C View Post
    Works here if Adobe Flash is running.
    May 2005
    1662
    or this?
    https://www.cnczone.com/forums/uncat...-software.html
    The more the merrier ?
    Do you tried Inkscape with G-Code plugin ?
    Feb 2012
    17
    ger21
    Probably found the cause:
    Attachment 446654
    Replace in source "http" -> "https"
    Feb 2012
    17
    But the tool still needs some beta testing, I will appreciate any help.
    May 2005
    1662
    It seems Makercam only behaves with some browsers and security settings.
    The death of Flash will not be mourned.
    Dec 2012
    192
    Hello.
    For an unknown reason I could not reply with a PM.
    What I will be doing is using some of my already converted files so that it will be possible to compare the generated G codes. Then I will run them on my viewer and watch their execution. I´ll try to post the video files.
    Regards.
    Feb 2012
    17
    cyclestart
    They all have a fatal flaw
    https://www.drdobbs.com/windows/a-br...ng-r/225701475
    Feb 2012
    17
    Dec 2012
    192
    Hello.
    The posted files are the ones I´ll be using to test your software. This is the type of patterns that our new machine will be required to quilt.
    I´m in the process to convert these files using the technique I already have. This far I have the DXF´s.
    I´ve also included the original SVG´s in case you want to experiment on your own although I don´t think it is what you want.
    The filename extension was changed to txt as the uploading protocol does not allow SVG files.
    I will post my results as soon as possible.
    Regards.
    Jul 2014
    5
    I also am looking for a SVG or DXF to gcode file converter for my quilting machine. Did you have any luck finding one?
    Feb 2012
    17
    BBMNet
    Answered in the private message but couldn't send file, sending here.
    Splitted the sample into multi simple shapes, because complex shape will probably run into calculation timeout.
    Feb 2012
    17
    Hi, recently most of people who tried to use the converter tried to convert plain SVG without path descriptions. It will not work because the converter doesn't know how to process the path (from outside or inside, mill cavity or just draw outline). We shoud say which operation to apply to each path we want to cut, by adding a description to the path.
    In the SVG source it looks like:
    <path d="m 173.7147,158.02643 77.7675,0 c 22.43224,0 40.4914,18.05917 40.4914,-40.4914 z">
    <desc>fill z=-0.5...-11 dz=0.5...2...2 part-name</desc>
    </path>
    Possible keywords are:
    "cut" - cut the shape
    "fill" - mill the shape as a cavity
    "outline" - like fill but just cut inner outline
    "zigzag" - like fill but without inner outline
    and
    "blank" - the rectangle converted to path - all shapes will be placed relatively to blank
    In the Inkscape editor it looks like:
    The red rectangle here is a "blank" path.
    Full tutorial is here:
Page 1 of 2 12
  1. DXF to G Code Converter
    By Doubleddaved in forum Haas Mills
    Last Post: 03-29-2019, 03:48 PM
  2. G-code to DXF Converter
    By fst14me in forum Want To Buy...Need help!
    Last Post: 04-08-2013, 05:36 PM
  3. g code converter
    By chrispare in forum G-Code Programing
    Last Post: 08-12-2009, 10:51 AM
  4. 3D dxf to g code converter
    By gaanes in forum Uncategorised CAM Discussion
    Last Post: 06-01-2009, 02:11 PM
  5. Looking for a .dxf to G-Code converter...
    By sciontim in forum OpenSource Software
    Last Post: 06-03-2008, 06:30 PM
