585,875 active members*
3,998 visitors online*
    Dec 2006
    Tube and power supply upgrade
    Hi all,
    my 80W laser tube failing (the cooling water go everywere in the tube, also in the inner tube), so I bought this 2 product:
    https://www.vevor.com/collections/la...utting-machine
    https://www.vevor.com/products/150w-...106f6cd7&_ss=r
    I choose a bigger power supply to future upgrading. But now I notice that the laser tube need 26KV, instead power supply voltage output is 34KV.
    I understood that the output power is adjust with current set from controller, but how can I set the voltage? Or the voltage is
    proportional to current?
    Thank you for your support.
    By(t)e
    Dec 2006
    Re: Tube and power supply upgrade
    I answer to myself.
    Vevor (laser tube and power supply vendor) told me that the power supply auto-set the voltage to correct value.
    Anyway, today the tube arrived and I put in my machine with original power supply (80W 40kV). All work correctly (I think: the beam out from tube). I must align the mirrors and make an extension for tube coverage.
    By(t)e
  1. SH-G350 Upgrade to 60W Power Supply and SP Tube
    By Spookyeng in forum Laser Hardware
    Last Post: 04-06-2019, 09:46 AM
  2. Seeking advice before I upgrade my CO2 tube and Power Supply
    By coodem in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 01-14-2017, 08:52 AM
  3. Rapid Loss of Cutting Power- New Tube, Fairly New Power Supply
    By scrappyjedi in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 02-23-2016, 01:24 AM
  4. 60W co2 tube on 40W power supply?
    By Pairair in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-03-2015, 10:26 PM
  5. Is it the tube? Or the power supply?
    By SimonArthur in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-20-2008, 06:36 PM
