585,974 active members*
4,286 visitors online*
Results 1 to 6 of 6
    Jun 2010
    119
    Saftronics G3 issue
    Hello, I've got an older Saftronics G3 5hp 220V VFD that I got from an industrial surplus place. I stupidly didn't power it up before the return period was up. I just did tonight and find that it has a CPF05 error. I'm trying to factory reset it to see if it'll clear, but when I press the pgm button I don't get the no-01 it's supposed to. I get An-01. I can't figure out how to get to no-01 from there. I can find bn-01,Sn-01 and Cn-01,I think.
    Does anyone have any idea what's going on? I've looked thru the manual and I can't find these anywhere.
    Thanks!
    Mike
    Aug 2009
    1573
    Re: Saftronics G3 issue
    ...looks like an error code. try re-seating all the plugs, ic's, eproms, etc.. might get lucky its just a bad connection inside.
    https://s3.amazonaws.com/Icarus/DOCU...anuals_123.pdf
    Jun 2010
    119
    Thanks for that manual, I must have had the wrong one! I'll try reseating the chips and factory resetting tomorrow.
    Jun 2010
    119
    Well, I reseated everything I could and then reset the drive and am still getting the error code. I decided to take it all apart to see if I could see anything obvious wrong. I think I got lucky! There's one capacitor that's obviously bad and one next to it that may be too. The one is swelled and slightly open like they do and the other looks like it might be swelling. I'm going to replace them and see what happens. Here's hoping!
    15362
    Quote Originally Posted by EmeraldIsleforg View Post
    The caps are most likely well over due for replacement the normal replacement is every 2 years but not many people ever replace them, until they cause damage or take the boards out, which is usually to late, so yes you might have got lucky
    If these caps have caused any kind of short, they can take out the CPU which is where your fault was coming from
    Mactec54
    Jun 2010
    119
    Well, it looks like the caps weren't the only problem unfortunately. I replaced them today & still have the same error.
  1. Replies: 1
    Last Post: 01-08-2016, 06:58 AM
  2. Bridgeport with Saftronics G3u-22P - UV1 DC Bus Undervolt
    By thomasfreedy in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2014, 03:19 AM
  3. saftronics spindle drive inverter
    By fcycles in forum Want To Buy...Need help!
    Last Post: 02-11-2012, 06:04 PM
