585,602 active members*
3,418 visitors online*
    Jul 2007
    7
    Question Moriseiki MV 55 NC milling machine.
    Hello everybody. I'm a technician in VN factory.
    I've got a mechanical problem: Tool drops when I machining with heavy load. Something's wrong? Please help me troubleshooting. My email: [email protected].
    Oct 2006
    51
    do the tools drop only when you try to tool change after a heavy load?
    a quick check would be to mill with a heavy load, zero return the z axis, then have an m0(optional stop) before the tool change. take the holder out of the machine. if it is sticking in the spindle, you might want to check the drawbar and the spindle liner. if you put the tool back in, it should tool change fine.
    i would also check that the spindle orientation is correct after milling and before a tool change.
    Jul 2007
    7
    "you might want to check the drawbar and the spindle liner"?
    The worker's worked for 3 hours before the tool drop droped. We disassembed to check the drawbar and the spindle liner and assemble
    again many times. We don't have a lot experiences about this probems. I needs for your helps
    Feb 2007
    464
    Quote Originally Posted by TU ANH DUNG View Post
    Check the catchers that hold the pull studs.One might be broken or all of them worn out.
    Or it could be the spring washers.Some of them can be broken and the pull much lighter than it should be.
    We have had the same problem with one of our Mori Seikis.
  1. Moriseiki SL6 Ladder Diagram - Fanuc 6T
    By gowthu in forum Fanuc
    Last Post: 05-29-2022, 09:48 AM
  2. CNC milling machine
    By ebproseller in forum Mechanical Calculations/Engineering Design
    Last Post: 06-25-2007, 02:58 AM
  3. Moriseiki GV503 5 AXIS
    By CIVODUL4 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-24-2007, 03:00 PM
  4. Why would this machine be bad for milling?
    By jevs in forum Knee Vertical Mills
    Last Post: 06-17-2005, 04:49 AM
